It is entirely possible that a Windows 10 setting is interrupting the printer and stopping it working correctly. Here are a couple of things to look for. If you are facing any problem related to Apple Issues please visit:- https://www.brotherprintersupportnumber.com/blog/how-to-fix-brother-printer-offline-in-windows-10/
Did you run the Canon printer's Network Wizard (or similar) and enter your home network's SSID value? (this is a 9-digit number for your home network, provided by your cable/network provider when it was first installed). Ensure your printer is within a discoverable range from the network modem. If so, did you then install the Canon Wi-Fi/Network printer driver? (you will need to print using this printer driver and not the standard USB cable printer driver). If so, then activate a test page to ensure you are connected over the network. Then you can test file sharing with other devices and go from there.
Do you have the printer drivers installed on the originating device? have you connected it to your network?
You'll be using the wireless router to connect the new wireless printer to your home network so make sure the router is up and running. Most new computers and wireless printers are equipped with either Bluetooth or Wi-Fi capabilities. If your printer is not wireless you can purchase a wireless card that plugs into a USB port.
2. Select the Location of the Wireless Printer
The wireless printer should be set up in a place at home or in the office that is accessible to everyone and where there is ample space for paper, printer ink and other supplies. If you are using Bluetooth wireless you may want to give this some thought since Bluetooth printers have a smaller wireless range than Wi-Fi printers.
3. Enable Printer Sharing
The server computer's operating system must be informed that the printer you are adding to the network is a wireless printer. (The server computer is the one the printer is connected to.)
In Windows Vista, this is done by accessing the network settings in the Control Panel and then activating file and printer sharing in the local area network settings.
For Windows XP go to Start, Control Panel, Printers and Other Hardware, "View installed printers or fax printers." Right-click on your printer and select "Sharing", then select "Share this Printer." Give the printer a name and click OK.
4. Add the Wireless Printer to any other Computers on your Network
The other computers on the network must also be set up for using the wireless printer. To do this in Windows Vista, open the Control Panel in the classic view and then open Printers. Right click on the printer that is going to be shared, and then open Properties. In Properties, check the box that allows the printer to be a shared device.
For Windows XP you will need to do the following:
Both this computer and the one the wireless printer is attached to might need a reboot. If you're not seeing the computer it is attached to, double-check that all computers have the same network name: go to Control Panel, Performance & Maintenance, "See basic information about your computer." From there click on "Computer Name" and your workgroup will be displayed.
If you're not seeing the printer, make sure it's switched on. If printer still doesn't work, you may need to install the printer driver using the software CD that came with it.
