If you unplug the power cord from the wall and the PSU, then flick the little red voltage switch on the back up and then back down again, plug it back in and it should work again
hi t could be that your CPU fan is loose or that your RAM(memory) came loose try looking on youtube to see how to put RAM (memory) into pc and make sure your CPU fan is secure....bonnell
Check CPU and memory seated correctly, may have overheated so check fans working and heatsink clean of dust etc. The led should flash an error code. The number of flashes says what is wrong. There are some 9 codes, from bad to disasterous! see http://www.dectrader.com/docs/set1/emr_na-c00278580-1.pdf
Press Start-settings-profiles-normal(or profile wich you want to change)-press menu on the profile-then choose edit. And there you will find - Ring volume Alarm volume and others.
Anyway, you can always recover the information on your computer, but will have to take the hard disk out of the computer and plug it onto another as a secondary hard disk.
