20 Most Recent HP Pavilion a705w PC Desktop Questions & Answers
4answers
How do i download music to my computer
If you're looking to download music,
http://www.limewire.com/ will get you where you gotta go.
Download the program, run it, and search for whatever you want. Be wary of files with strange names for they can be dangerous.
Good Luck :)
8/16/2022 2:01:41 AM • HP Pavilion... • Answered on Aug 16, 2022
Have hp pavilion a705w and power button stays in after pushing to power on-then monitor goes off.
This might be because the battery died, I had the same problem but after replacing the battery it worked
4/7/2021 1:18:50 PM • HP Pavilion... • Answered on Apr 07, 2021
Can't reset password, disabled at jumpers
Try using cmd as administrator.
4/4/2021 3:04:21 PM • HP Pavilion... • Answered on Apr 04, 2021
Manual & schematics for hp pavilion a705w
HP Company makes no guarantee of any kind regarding the substance, including... directions and finish the first windows until you find the desktop. Refer to. "turning on... Here is the easiest fix to the HP computer.
2/10/2021 1:40:06 PM • HP Pavilion... • Answered on Feb 10, 2021
2answers
Having problems burning music from computer
What is exactly the problem, Does your computer have the software and the CD burner in it? What are the steps you follow to burn music?
Normally to burn the music from the computer , use Media player or any other software that can burn CD. Pick the music files to be burned from the local drive. Insert blank CD in the CD burner. Hit the burn to CD button from the CD burning software.
3/25/2020 9:25:55 AM • HP Pavilion... • Answered on Mar 25, 2020
Remove hard drive from hp pavilion 790
Dear Anonymous, http://h10032.www1.hp.com/ctg/Manual/c00225826.pdf pages 11->19 show detailed instructions on removing/replacing the HDD on this model computer. N.B.: Make sure the jumper link on the socket end of the new HDD is in the same/equivalent position as the old HDD. (If in doubt "C.S." or "Cable Select" is always a safe position.) Kind regards - 'b'ye, Bruce Gilbert.
7/31/2014 9:23:39 AM • HP Pavilion... • Answered on Jul 31, 2014
Where do the card reader cable go on an HP
Most card readers are plugged into a usb header on the main board.
5/4/2014 1:59:51 PM • HP Pavilion... • Answered on May 04, 2014
How do I test the sound card when the control Panel Sounds states no audio devices?
Try booting with a Linux disk and see if sound works. If so you most likely have a driver issue.
5/4/2014 1:25:27 PM • HP Pavilion... • Answered on May 04, 2014
Blinking light want start up
short the wires and put them back
4/1/2014 3:27:00 PM • HP Pavilion... • Answered on Apr 01, 2014
How do I test the Sound card when the Control Panel sound states no audio device?
You should check in Device Manager to see if your audio driver is installed and working properly. If not, reload it. You could also check in the BIOS setup to see if the onboard audio has been disabled. There is also a possibility that the onboard audio has failed. You can order a sound board to install in the nachine to restore audio capability. Just disable the onboard audio in the BIOS, install the card and load the drivers supplied with the card. Hook your speaker to the jacks on the new card and you're back in action.
12/7/2013 1:17:25 AM • HP Pavilion... • Answered on Dec 07, 2013
Inside diagram
You need to find the Mother Board diagram or manual, that will tell you were the pins are to plug it back in.Contact HP here is your motherboard: Giovani-GL6, Giovani2-GL6
10/26/2013 6:29:21 PM • HP Pavilion... • Answered on Oct 26, 2013
My hp pavilion 705 w wont connect to the internet
Need to call your Internet provider
9/4/2013 3:48:53 AM • HP Pavilion... • Answered on Sep 04, 2013
Motherword.hpa750w i,nid vuy one
do you motherboard i don't think you can.oem-pruduct.
4/4/2013 4:08:09 PM • HP Pavilion... • Answered on Apr 04, 2013
Have a hp pavilion a705w that shut down one day and upon restart NTLDR is missing error came up and said hit alt clt del what do i do
Windows was writing to a file when the power went off. Now windows files are damaged. I'm assuming you have Windows XP on the machine. Do you have your Windows XP cd?
3/16/2013 7:53:31 AM • HP Pavilion... • Answered on Mar 16, 2013
Error while unpacking program, code E2. Please report to author.
You might have some viruses and malware......Start your PC and press F8 several times until the boot menu comes up. Then select "Safe Mode with Networking". Now get some or ALL of the FREE programs below.Download, Install and Run Malwarebytes Anti-Malware:http://majorgeeks.com/download.php?det=5756When Installing choose the non-pro version.Download, Unzip, Install and Run TDSSKiller:http://majorgeeks.com/Kaspersky_TDSSKiller_d6895.htmlDownload, Install and Run Super Anti-Spyware:http://majorgeeks.com/SUPERAntiSpyware_d5116.htmlIf you have an outdated Anti-virus program then Download, Install and Run Avira Anti-Virus:http://majorgeeks.com/Avira_AntiVir_Personal_-_FREE_Antivirus_d955.htmlMake sure to select ALL of the "threat categories" when you install or configure Avira...You should be in pretty good shape if you run and install all of these programs.
6/29/2012 2:41:01 AM • HP Pavilion... • Answered on Jun 29, 2012
APPLICATION HPSU -0004 MISSING FROM LIBRARY
Basically, the HPSU-0004 Error states that one or more DLLs (libraries) needed for the Update utility to run are missing.The libraries were deleted, or pointers to irrelevant libraries were left in the Registry.2 Possible Solutions:The EASY solution:1. Remove all of your HP (Hewlett Packard) Printer software from your computer and do a fresh install from the CD that came with your printer.The Hard Solution (only do this if the easy one doesn't work):1. Download a current version of the FULL drivers+applications (single HUGE file) for your printer;2. Start running the file downloaded in the previous step, until it offers the option to install the software (other options might be there, such as "read the Readme file");3. Do NOT click on "Install", but rather simply exit the Installer (cancel, exit, ...) - the reason for step 2. above was to just have the downloaded file extract in an orderly manner all the files that it (and YOU) would use for its (and YOUR) further processings;4. Locate on on your drive the installation folder created in step 2., and -- under it - the folder "setup\hpupdate" (the whole thing should be located somewhere under the TMP or TEMP folder - just run a Search/Find for it, using your search engine of choice);5. IF (and only if) you have located the HPUPDATE folder in the previous step (you will, normally), continue:6. Under Windows Control Panel, start the "Add/Remove Programs" applet, and -- in the list of applications it presents -- look for "HP Update";7. Remove the HP Update application as you would any other application (the uninstall process might end with some errors for files not found - this is normal in this case, as we already know that some files are either missing, or mistakenly pointed at, as stated earlier in this text);8. Now go to the setup\hpupdate folder located in step 5. above, and run (double-click on) the only *.msi fie found within it (this will reinstall the version downloaded of the HP Update utility);9. When Installation (previous step) is completed, run the newly installed HP-Update utility, to find further updates both for itself (you might not have had the most recent version) and for any other HP application that might reside on your drives.10. This completes the processGood Luck!
5/17/2012 3:33:24 PM • HP Pavilion... • Answered on May 17, 2012
HP Pavilion a705w PC Desktop Logo
196 questions posted
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Pavilion HP
  • Pavilion HP
Most Popular Question
pic or diagram shows all wires plugs
  • Computers & Internet
