20 Most Recent
HP Compaq Presario SR2011WM PC Desktop Questions & Answers
Have dx2480 business pc
Error "
Just check the tower all the nuts and blots should be tightend...reset the bios may also help ypu..if you like please rate..thanks
5/2/2015 7:42:09 AM •
HP Compaq...
Answered
on May 02, 2015
912-the computer has been removed.the
Make sure you close the case cover first before performing the steps below
1. Go to BIOS by pressing F10
2. Select hardware monitor setup and enable the reset case open status ANOTHER SOLUTION IS
1.turn on ur PC.
2. press F10
3. wait 10 sec.
4. press "right arrow" 1 time
5. press "enter"
6 press the "+" sign on ur numeric pad
7. press F10
8. press "enter"
5/20/2014 8:03:03 AM •
HP Compaq...
Answered
on May 20, 2014
Network cable is unplugged
sometimes the adapters can be turned off in software go to network and sharing center and make sure your adapters are not diasbled
7/7/2012 12:07:28 PM •
HP Compaq...
Answered
on Jul 07, 2012
Pentium 4 upgrade
The Compaq Presario SR2011WM supports following processors:
CPU/Processor
- Socket: 775
- Supports the following processors:
- Pentium D 900 series Dual Core
(Pressler, 65nm)
- Pentium D 800 series Dual Core
(Smithfield, 90nm)
- Pentium 4 601 series (Cedar Mill, 65nm)
- Pentium 4 600 series (Prescott, 90nm)
- Pentium 4 500 and 501 series (Prescott, 90nm)
- Celeron D
Hope it helped.
6/27/2012 7:26:43 PM •
HP Compaq...
Answered
on Jun 27, 2012
Problems downloading programs
This all depends on what your downloading why your having issues. Cannot assist if I do not know the operating system as well as what your downloading. Could you be more specific please.
4/9/2012 12:15:20 AM •
HP Compaq...
Answered
on Apr 09, 2012
Compaq presario SR2011WM Desktop reboot and select proper boot device
not sure what you mean but
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode
click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred
you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work hope this helps you
3/30/2012 11:43:55 PM •
HP Compaq...
Answered
on Mar 30, 2012
When switched on my pc
This error is displayed if chassis intrusion protection is enabled and the cover is removed.
But as I remember you can bypass this message and start the computer. I don't remember the key, but try Escape or Enter key. (I think the button to skip this error is displayed below the message).
You can also go to BIOS and disabled Chassis intrusion detection.
9/5/2011 8:28:07 AM •
HP Compaq...
Answered
on Sep 05, 2011
