Amana washing machine is stuck in a delayed status and door is stuck locked
SOURCE: maytag neptune washing machine door not locking
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
SOURCE: installing new washer and plug is stuck inside washer.
On this unit you will need to removed the shipping bolts before the plug will release. It is so important that these bolts be removed that the manufacture designed the plug to be stuck inside until all 4 bolts are properly removed.
The installation guide will have instruction on how to properly remove or post a comment to this if you have questions and I will do my best to address them.
SOURCE: how do you reset the washer it keeps beeping and
unplug washer for about 5min. that should reset it
SOURCE: Amana NFW7200TW washer - door seal ring has detached
The ring is a clamp that keeps the rubber part, called the bellow, attached to the front panel of the washer. To reinstall hook the edge of the bellow around the lip of the opening in the front panel (the hole through which you put your laundry). Then take the clamp and seat it in the groove of the bellow behind the lip of the front panel. The spring on the clamp should pull the bellow tight to the opening of the panel.
Like so:
SOURCE: The washer door is locked and will not open
Problem with Maytag MHWE450WW front load Maytag washer. The washer door is locked and will not open. I tried several suggestions in the manual, but none work. Please help!!! My email address is
[email protected] and my name is Antoinette Roy
