How do i reset the waste ink error message
Canon Error Codes
L5000,5500,7000,8000: To enter service mode Data Registration, #, Ram Clear is under #8 clear
Faxphone 20 ram clear
Turn off the power switch
Turn off the memory protect switch (located on the bottom of the machine)
Turn the power on
Press function # 2 0 start
Turn the power switch off
Turn on the memory protect switch
Fax L770 fuser gear wears out easily under heavy usage. White gear with 2 sets of teeth.
Inkjet models such as the B160 will hold faxes in memory and refuse to print if excess ink has accumulated on the pad under the cartridge's nose. Remove the cartridge and wipe up excess ink with a cotton swab.
My mp780 was rporting waste ink full. and now just says check printer. I cleaned the foam pad and put it back in but it still wont clear or reset.
