SOURCE: Even after putting new batteries it gives message"change the batteries"
Are you still using alkaline batteries? If so, alkaline batteries just don't have the power for more than a few pics in a digital camera. Some may have reached their shelf life, and though brand new, may even have problems just powering startup of the camera. Digital cameras for the most part should only be used with rechargeable NiMH batteries. Retailers sell these for around $7 for a package of four (about $15-19 for the batteries with charger). Keep in mind they'll save you big bucks in the long run over alkalines, AND they'll last for at least 100 pictures per charge (and probably many many more). You'll be very pleased with their performance, and may slap yourself for not buying them sooner. When at the store, look on the package for a power rating of at least 2500 mah.
SOURCE: Camera won't work. Only shows Change Batteries,even with new ones
akaline batteries wont work
only rechargable FULLY CHARGED
if that doesnt work clean battery terminal
SOURCE: even when i put new batteries in my canon
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the
probability is that you will have to get it fixed by a professional.
Use
these at own risk as it may further damage the camera.
Firstly ,
try connecting your ac adapter or usb cable.
Try holding the
shutter button while switching on the camera.
Look at the lens ,
and if some of the lens 'circles' is misaligned or not concentric then
try wiggling it (while holding camera lens down).
Try gently
pushing or pulling the lens when it extends but this is risky as it may
cause the lens barrel to slip out of its guidance system.
Another
way to do this is to place the camera lens down on a hard surface and
then power it up. Be sure to use a soft cloth or something similar as to
not scratch your lens or casing. Let the lens push the camera up and
down a few times and sometimes the little resistance provided by the
camera is enough to get things going again.
Try hitting your
camera near the lens on the body with the soft tissue on the palm of
your hand.
Other than that , I would take the camera to a repair
center for a evaluation to see if it would cost more to repair than to
replace the camera.
If it is still under warranty I would suggest
you take it in before trying any of these steps and remove any
off-brand batteries or accessories as some stores are really fussy about
warranty repairs on camera's with non-brand accessories.
Hope
the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
SOURCE: Canon IXUS 100is battery pack problem.
Happened the same with mine. At the beginning I tough it was related with the sd card as when I removed the card the camera would turn ON. Later on I found it to be related with the camera contacts. After cleaning the battery contacts with alcohol and a cotton swab it started to work fine. SOLUTION: Clean battery gold contacts.
SOURCE: My Canon S2 IS keeps saying 'change the battery'
there is a little coing battery located inside the battery compartment for the AA's. CR1220 you can get this at Radio Shack for about $5. If this battery is bad you will get the change batteries screen no matter how many fresh AA's you put in, Use a good quality alkaline battery such as the Energizer rechargable rated at 2700 mAh.
