20 Most Recent Canon PowerShot A490 Digital Camera Questions & Answers
2answers
Camera says lens error, restart
Hi, On Canon camera's that error is typically seen when the camera's been dropped and the lens is now out of place. For the A490 specifically that's something that can't be fixed as it's such an inexpensive camera and fixing that problem, if it can even be fixed, costs upwards of $300.
12/26/2014 3:17:17 PM • Canon PowerShot... • Answered on Dec 26, 2014
Picture becomes white at day time
Could be that your camera is exposing incorrectly if you could upload a photo that was taken I could have a look at the metadata and could advise you from there.
12/1/2014 10:12:48 PM • Canon PowerShot... • Answered on Dec 01, 2014
When I try to download most recent pictures I am forced to download all that are on camera
It depends on what software you are using to transfer photos from the camera to your computer. If you install and use the "Camera Window" transfer software Canon included with the camera, you will see you have three modes to choose from, including the option to transfer just the photos on your camera that have not yet been transferred. Connect the camera with a USB cable to your computer. Power up the camera. The computer will detect the camera, and open a dialog box offering you a choice of programs on your computer that can handle photo transfers. If you choose the Camera Window software, it will open and present a menu with three choices of action. The first option is, "Import images from Camera." Select this. Another submenu opens presenting these three options: 1. Import Untransferred images. (this is what you said you want) 2. Select images to Import. (manually select just certain ones) 3. Import All images (automatically transfers every image on the card) Menu screenshot, Canon's "Camera Window" transfer software2d13ae76-841e-450d-995d-43cd3e2dd7e6.png Camera Window is just one of many available image transfer applications you could use. They all do essentially the same three things outlined above, including "Import Untransferred images." Canon included a couple other utility programs on the CD that came with your Powershot A490 camera. One of them, "Zoom Broswer EX" enables you to reload photos from your computer, back on to your camera's image card, if you want to do that.
6/5/2014 7:44:37 AM • Canon PowerShot... • Answered on Jun 05, 2014
Communication error on screen
Try NOT connecting your camera to your computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
4/15/2014 4:06:20 PM • Canon PowerShot... • Answered on Apr 15, 2014
Canon a490 is stuck in movie mode. have reset it. swapped batteries etc. nothing works.
Did you try to change the mode, like is displayed on page 28 of the manual? 4106cd5a-7a9e-45c3-936d-83891ecbaadb.png
2/27/2014 5:39:03 PM • Canon PowerShot... • Answered on Feb 27, 2014
When I turn on my Canon Powershot A490 I get the
Restart just means to turn it off and then on. That rarely actually works. Try these:
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include "E18 lens error", or "lens error, restart camera". Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many cameras, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in "no heat" setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
2/5/2014 4:30:46 PM • Canon PowerShot... • Answered on Feb 05, 2014
0answers
Memory card locked
And you looked if the card was locked? The 64GB card is unlocked the 32 GB card is locked. So make sure the switch is up when you see your card like these two. When you are sure your card is unlocked, just check if all contacts of the card and in the camera are still clean, shiny, and straight. (no bent in any contact) 34656195-d34c-4439-a680-4f5fbfec2107.jpg
1/18/2014 12:02:41 PM • Canon PowerShot... • Answered on Jan 18, 2014
0answers
Lens shutter not opening completely
Lens block faulty replace it.
10/16/2013 1:11:54 PM • Canon PowerShot... • Answered on Oct 16, 2013
When I plug the camera into the computer it says connection error
My camera cannon powershot A490 always tells me that my batteries are low and cut's off even when I have just changed my batteries
5/31/2013 10:08:22 PM • Canon PowerShot... • Answered on May 31, 2013
Canon PowerShot A490 Digital Camera Logo
87 questions posted
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
View Most Popular
PowerShot Canon
  • PowerShot Canon
Most Popular Question
memory card locked
  • Cameras
