Vacuums Logo
Posted on Jun 13, 2009
Sponge filter I have a kirby sponge filter for my Sentria shampoo system and dont know where it goes. It stop working and making foam. Kirby sent me the sponge filter saying this is what i need and i would know where it goes. I dont nor kind I figure it out. please help!!!!!!!
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Jul 19, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
Helped
11291
Points
31
On the end of the shampoo tank where it attaches to back of motor where the bag is normally attached
I am shampooing a berber carpet with my Kirby Ultimate G and no excess water or suds accumulate in tray. Either while suds dial is on or off. Why do suds come out under tray in straight line no matte
SYSTEM:
Will work with:
  • Kirby G3 vacuum cleaner
  • Kirby G4 vacuum cleaner
  • Kirby G5 vacuum cleaner
  • Kirby Gsix vacuum cleaner
  • Kirby Ultimate G vacuum cleaner
  • Kirby Ultimate G Diamond vacuum cleaner
  • Kirby Sentria vacuum cleaner
  • Sentria II (Sentria2)
This is unused shampoo attachment. We buy new parts and assemble this shampoo attachment so you will be the first one to use it.
Set includes:
  1. Tray with shield
  2. Nozzle
  3. Brush roll
  4. Belt
  5. Container with cap
  6. Hose
  7. 12 oz. shampoo
NOTE - pictured Kirby Sentria shampooer box may not be included.
If you have never used this shampoo, we highly recommend reading our ONLINE MANUAL. This is a simple but very effective unit but you have to learn how to use it and "common sense" will not be enough! HOW TO - V I D E O S
Tank with soapy solution is attached in place of the bag. It utilizes the air coming out of the exhaust to blow soapy water on a small screen that turns it into thick foam. The foam is simply laid over the carpet (you must vacuum before you shampoo). Foam allows the spread of a small amount of water over the area so carpet is not soaked all the way through. Foam is left on the carpet for a few minutes so it has just enough time to moisten the fibers of the carpet and loosen the dirt (not too long otherwise foam may dry). Then foam maker is set to "OFF" and you slowly pull Kirby vacuum over the area where you laid the foam. The rotating brush in the shampooer nozzle rubs the moisture off carpet fibers and and throws it into the tray in front of the unit. You will not see gallons of dirty water but that is because you did not put it on the rug in the first place. Carpet should dry within 1-4 hours (depends how many times you laid the foam and what is humidity in the room). After it dries it has to be vacuumed. Solution that did not get picked up with the shampooer brush dries and shampoo additives do not let the dirt stick back to the fibers of the carpet. It is loose when it dries so in order to pick up what is left, you must vacuum again.
Shampoo:
You can use any carpet shampoo sold in your local store but make sure that this is carpet shampoo that makes foam and pay attention how much you have to dilute it with water as various shampoo products come in different concentration. Avoid using "just anything" that makes foam. Some household chemicals (such as dishwasher fluid) will do great job but it will leave carpet unprotected so dirt will stick to it so well that you will have a filthy rug in no time. Kirby Vacuum Shampooer
800-775-6586
GoodVac com
Kirby Shampoo system not dispensing foam
Few possible causes
1. Valve under the sponge (water tank) is clogged. Replacement HERE.
2. Tray is now lowered all the way down.
3. You use non-foamy solution.
4. Carpet is very dirty so foam gets broken up very fast
Hope this helps,
Rocky
5helpful
2answers
It's been awhile since I have used my shampoo system on my Ultimate G series Kirby. Well, as instructed I took it apart and cleaned it. Now I can?t figure out where to put the ?screen cap? and ?sponge...
The littlew round screen goes in the hole where the hose attaches to the tank. The round foam filter goes up in the hole underneath the on/off valve for the foam. Here is a guide if you need any more help...
http://reviews.ebay.com/KIRBY-CARPET-SHAMPOOER-INSTRUCTIONS-MANUAL-DIRECTIONS_W0QQugidZ10000000004594992
Marci
Kirby sentria shampooing not right
make sure u put the exact/right instructed amount of soap in the tank.....after each room, wash & clean tank filter. open tank all the way.....pull back slowly. if too much foam...adjust tank knob.
3helpful
2answers
Having trouble shampooing
I found this on a website. Hope it helps others...
by Mainelyvacs in: Kirby
  • First a short explanation of how the Kirby shampoo system works: Kirby uses a “Dry Foam” type of shampoo. Basically, it spreads a shampoo foam solution on the surface of your carpet. This foam needs to stay on the surface of the carpet until it is completely dry (usually 1 to 2 hours depending on temperature and humidity) As the foam dries, it soaks up grease and dirt. You then vacuum the carpet and up comes the shampoo residue along with the absorbed dirt and grease. It does a very good job on the surface but will not extract stains from the bottom of the carpet or carpet pad. Several other brands such as Electrolux, Hoover and Koblenz make Carpet Cleaning machines that use the same system.
    So, you’ve read your manual, you’ve removed the carpet cleaning nozzle and the bag assembly from your Kirby, you’ve installed your shampoo tank and carpet shampooing nozzle tray and you start to shampoo but all you get on your carpet is a puddle of soapy water and no foam. Here’s a few things to look for:
  • Make sure you are using a Dry Foam Shampoo(preferably Kirby) and NOT an extraction shampoo, the Rug Doctor shampoo you had left over from your last rental will not work.
  • Make sure you have the correct mixture. If you are using Kirby Dry foam shampoo you simply fill the tank with water and put a tank cap full of shampoo in with the water. You can use other brands of “Dry Foam” shampoo, but the mixture ratio may be different, so read the label first.
  • Don’t reuse last year’s leftover mixture, it’s probably no good.
  • Make sure a family member didn’t pour any leftover mixture back into the empty shampoo bottle - further diluting a mixture will not produce any foam.
  • Don’t use shampoo that’s seen extreme temperatures.
  • Check the tank and make sure that the sponge filter is in place and if it is in place that it is not deteriorated. The sponge filter is located under the tank at the point where you attach the tank to the hole that you removed the bag assembly from.
  • Check the hose that runs from the tank to the nozzle. It should have a screen in the end that attaches to the tank (older models had a cloth screen with a metal retainer, models after 1989 have a 1 piece metal and plastic screen.
While shampooing w/my Kirby the water/shampoo comes out to fast.
On the water tank, there is a screen that attaches to the water tank itself, then the hose connects to over this screen on to the water tank. Then is also a round sponge that goes between the water tank and the vacuum base. Are both the screen and sponge there. If not, that's more than likely you problem. The screen is what creates the "Dry Foam".
2helpful
2answers
Carpet shampoo system
MY FIRST QUESTION IS WHAT BRAND OF SHAMPOO ARE YOU USING??? KIRBY IS NOTED FOR REQUIRING ONLY, KIRBY SHAMPOO. PART OF THE REASON IS THAT THEY HAVE A UNIQUE FORMULA THAT WORKS SPECIFICALLY WITH THE KIRBY.
THE OTHER POSSIBILITY IS THE DISPENSER IS PLUGGED AND NEEDS A REAL GOOD CLEANING. ALSO, WHEN APPLYING THE FOAM TO THE CARPET, YOU NEED TO GO REALLY, REALLY SLOW.
THE NARROW BAND OF SUDS DOES INDICATE YOU MAY BE MOVING THE DISPENSER TOO FAST. GOOD LUCK.
1helpful
No suds when shampooing
The sponge filter is in the large opening on the underside of the kirby shampoo tank. It is where the shampoo tank connects to the kirby. The cap the manual is referring to is the shampooer tank cap. It looks like a cup.
If the mesh screen in the hose is in place (try pulling it out of the hose and seating it in the tank where the hose connects.) and you're still having very little suds...(I'm assuming you're using Kirby shampoo as well)...I would suggest going slower when yours "laying down suds". And lower the shampooer head all the way to its lowest setting. I have found if there are a lot of oils in the carpet, the emulsifiers in the shampoo break down quickly and make the suds "disappear".
Be sure to go back over the carpet with the tank in the off position to scoop up any excess moisture. If excessive oil (from cooking, barefeet, and pets are main causes) is the cause of the lack of suds, numerous shampooings will rectify that situation.
Hope this helps!!
Shampo system
here is a site that has detailed instructions for using your kirby shampooer.
the screen that goes in the hose is different from the filter (round flat sponge) that goes between the exhaust side of the kirby and the shampooer tank. The screen is what makes the suds...if its not seated properly or missing (or damaged) then it won't make suds.
http://www.greatvacs.com/shampoo.shtml
this site shows a picture of the piece I'm describing...its the 3rd picture down, called the gauze filter...still its different from the sponge filter....
also...make sure you go slowly with the kirby (and lower it to its lowest setting) if your carpet is heavily soiled....the enzymes in the shampoo are what clean the carpet (oils, grime, etc) and if its heavily soiled the suds disappear almost immediately.
Hope this helps!!!
Shampoo-er
It goes on the small hole on the tank where the hose attaches to it. The sponge goes in the hole directly under the on/off valve. Here is a link to my online shampooer instructions.
Marci
Top Vacuums Experts
AskDyson
AskDyson
Anonymous
Are you a Vacuum Expert? Answer questions, earn points and help others
