20 Most Recent Kirby G6 Bagged Upright Vacuum Questions & Answers
go to a vacuum repair shop and take the old bulb with you along with the model number and make of your vacuum cleaner
Kirby G6 Bagged... | Answered on May 19, 2018
When you hit the foot pedal does your circuit open and close when you chk for continuity or is circuit open when switch is 0n ?
Kirby G6 Bagged... | Answered on Dec 15, 2017
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
http://kirbywhq.powweb.com/manuals/Gsix/F8AD0C717F117A3407F6C15466201173/G6%20Manual.pdf
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Kirby G6 Bagged... | Answered on Nov 26, 2017
There could be a problem with the motor or the switch. Electrical problems like this should be done by a qualified repair person for safety's sake.
Kirby G6 Bagged... | Answered on Oct 18, 2017
Start by checking to insure you're getting proper voltage through the cord. Make sure the bag emptor and front brush roll nozzle are installed properly as each must activate the switch for it to run. It could have a defective switch.
Kirby G6 Bagged... | Answered on Mar 03, 2017
Does It make the noise all the time or only when the machine is moving. If it does it only when you push the vacuum that noise is normal. The older Kirby transmissions make a whining noise when pushed.
Kirby G6 Bagged... | Answered on Dec 01, 2016
Take the belt off machine, try machine with the belt off, if motor sounds OK, try spinning the brush before putting belt on, if brush does not spin freely, see what is clogging it.
When brush spins freely, reassemble correctly and try.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Kirby G6 Bagged... | Answered on Mar 24, 2016
I've had that exact issue with a Kirby Diamond Edition. What has happened is that the bracket inside the machine that activates the forward and back motion of the tech drive has come out of its slot. The only way to fix this is to disassemble the machine and put it back into place.
Kirby G6 Bagged... | Answered on Mar 23, 2016
It usually means you have no filter or a defective filter in your shampooer hose,or your not using kirby shampoo.
Kirby G6 Bagged... | Answered on Mar 22, 2016
Odds are that the problem is not with the belt or the pulley, but with an agitator (rotating brush) that isn't turning freely. Remove the rotating brush and check to see that it spins freely. If not, you would either need to disassemble it (removing the end caps) to see if removing whatever hair / diebris is stuck between the end caps and the body of the agitator, and if that doesn't cause free rotation, then it means your agitator bearings are likely bad which means you will need to replace the agitator assembly.
Kirby G6 Bagged... | Answered on Sep 06, 2015
Check to see if the straw is present and attached correctly inside the jar.
Kirby G6 Bagged... | Answered on Mar 11, 2015
The vacuum bag's boot and the power head or hose with piece protruding from it must be hooked up or the motor will not start.
There is a switch on the bottom front that must be pushed in at the same time the slider switch where the bag's boot connects and turns must be slid to its max.
That is where it must be very clean for if that switch will not move the motor will not start.
Also, the electrical cords on that model were not a good make and one side only on the plug to the vacuum would always have no continuity.
I hope this helps!
William R!
Kirby G6 Bagged... | Answered on Feb 02, 2015
Here is a step by step walk through with pictures on how to replace the neutral / drive pedal on any Kirby Generation vacuum (G3, G4, G5, G6, Ultimate G, Ultimate G Diamond Edition, Sentria and Sentria II)
Kirby Neutral Drive Pedal Replacement Guide
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
Kirby G6 Bagged... | Answered on Oct 15, 2014
You need a new screen on your tank. It's the little tiny round plastic one that fits onto the tank where the hose plugs into it. (not the foam one) Yours may be wedged sideways in your tank hose (this is a common occurrence) If your screen is damaged (loose around the edge) you will need to buy a new one.
Kirby G6 Bagged... | Answered on Sep 15, 2014
Nissan Frontier Forums Replacing Drive Belts
The above link should give all the info you need. Towards the middle of the page there is a step by step description.
Kirby G6 Bagged... | Answered on May 24, 2014
contact your local kirby agent for this, you will have to strip motor down, if you take off front housing you will break seals
Kirby G6 Bagged... | Answered on Apr 29, 2014
tends to be a fault in cable
Kirby G6 Bagged Upright Vacuum Logo
238 questions posted
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Kirby Vacuums
  • Kirby Vacuums
Most Popular Question
kirby g6 not vacuuming
  • Vacuums
