20 Most Recent Kirby G5 Bagged Upright Vacuum Questions & Answers
Kirby G5 gearbox clicks, why?
most of the time the small fork that comes off of the transmission and connects to the top slide wears out which doesnt allow the transmission to engage properly
12/20/2021 8:28:25 AM • Kirby G5 Bagged... • Answered on Dec 20, 2021
I need a owners manual for a Kirby G5 vacuum cleaner
Hello, this is Ava with Think Crucial. You may find the User's Manual for your Kirby model by clicking the link below. Kirby G5 Owner Manual You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Kirby I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
11/21/2017 5:36:30 PM • Kirby G5 Bagged... • Answered on Nov 21, 2017
My kirby is shorting out when i plug it in and
It sounds like you have a short in the wire. At some point the wire was partially cut or it has broken inside the case due to bending. If it is sparking, you need to fix it before you use it or it will blow something in the machine by surging power to it or possibly set your carpet on fire rather than clean it. if you are comfortable fixing it yourself you can carefully cut the insulation casing away from the wires; don't remove it just cut a slit in it so you can access the wires inside. you will want to cut the wire completely where the short is. You will want to strip the two ends and reattach them then wrap them with electrical tape. try not to cut way too much or you will have a problem that one wire is significantly shorter than the other. Then just fold the insulation case back over the wires and wrap the entire section with a healthy amount of electrical tape and you should be good. or you can simply replace the entire wire. If you still have a warranty you can ask if this is covered. If not you can purchase a new wire online. I found one on Amazon for $75 CDN https://www.amazon.ca/Kirby-Ultimate-Generation-50-Electric/dp/B00KDPR4GK/ref=sr_1_fkmr0_4?ie=UTF8&qid=1507822242&sr=8-4-fkmr0&keywords=kirby+vacuum+parts+wire This part is being sold by the manufacturer and is not a 3rd party parts dealer. Let me know if this helped.
10/12/2017 3:43:25 PM • Kirby G5 Bagged... • Answered on Oct 12, 2017
Where is Johannesburg service centre?
    Kirby (Best appliances) Vacuum Cleaner Repair Shop Address: 2030 south, 189 Smit St, Randburg, 2030 Phone:011 476 1235 Hours: Open today ยท 7:30PM-5AM
2/2/2016 6:17:54 AM • Kirby G5 Bagged... • Answered on Feb 02, 2016
2answers
Carpet shampoo system
MY FIRST QUESTION IS WHAT BRAND OF SHAMPOO ARE YOU USING??? KIRBY IS NOTED FOR REQUIRING ONLY, KIRBY SHAMPOO. PART OF THE REASON IS THAT THEY HAVE A UNIQUE FORMULA THAT WORKS SPECIFICALLY WITH THE KIRBY.
THE OTHER POSSIBILITY IS THE DISPENSER IS PLUGGED AND NEEDS A REAL GOOD CLEANING. ALSO, WHEN APPLYING THE FOAM TO THE CARPET, YOU NEED TO GO REALLY, REALLY SLOW.
THE NARROW BAND OF SUDS DOES INDICATE YOU MAY BE MOVING THE DISPENSER TOO FAST. GOOD LUCK.
11/8/2015 12:35:22 AM • Kirby G5 Bagged... • Answered on Nov 08, 2015
2answers
My Kirby shampooer wont foam
Start with the hose OFF the tank (make sure small filter is in place).Fill the tank with water and KIRBY DRY SHAMPOO (other shampoo's wont foam) then turn the vacuum on. At this time the shampoo will come out as a stream of foam. If the shampoo come's out as liquid then you will need to check the tank. If shampoo was left in the tank ,then the pick-up hose inside the tank my be colgged. These are hard to un-clogg so replacement of the tank may be needed.
3/9/2015 5:57:16 PM • Kirby G5 Bagged... • Answered on Mar 09, 2015
How do I disassemble a suction blower connector from the hose on a sweeper?
Here is a walk through on installing the attachment hose, just reverse to remove the hose: Vacuuming Bare Floor with Kirby vacuum 800-775-6586 GoodVac com
2/27/2015 6:15:19 PM • Kirby G5 Bagged... • Answered on Feb 27, 2015
2answers
G5 kirby's drive feature isn't working
the gears or the drive is probably worn down or is broken.take it into kirby and they can fix it for you.
10/16/2014 9:05:16 PM • Kirby G5 Bagged... • Answered on Oct 16, 2014
2answers
Kirby drive wont go in reverse.
The slide will need to be adjusted (may of come loose )
8/21/2014 5:39:48 PM • Kirby G5 Bagged... • Answered on Aug 21, 2014
In drive I can push kirby forward but not backwards
it will be the transmission this video will help you
8/15/2014 5:59:47 PM • Kirby G5 Bagged... • Answered on Aug 15, 2014
How to replace a switch in a kirby sentria vacuum
you need to find your nearest Kirby service dealer as its got a lifetime guarantee and when they fix it for a fee they will go over it to make sure there is nothing else wrong with it.
8/7/2014 8:35:02 AM • Kirby G5 Bagged... • Answered on Aug 07, 2014
I need to find the serial number. how can I do that
trad to leg on front casing, gen 3 to gen10 on side of casing
4/29/2014 11:21:55 AM • Kirby G5 Bagged... • Answered on Apr 29, 2014
Manual for Kirby G5
kirby.com or ebay for used one
4/29/2014 11:18:27 AM • Kirby G5 Bagged... • Answered on Apr 29, 2014
Kirby G10D wont power on
head or bag system not fitted correctly refit both
4/29/2014 11:02:18 AM • Kirby G5 Bagged... • Answered on Apr 29, 2014
Kirby G5 only works when the power button is being pushed.
power switch damaged contact your local kirby agent for repair
4/29/2014 11:01:34 AM • Kirby G5 Bagged... • Answered on Apr 29, 2014
My on,off button came off how do i fix it
get local kirby enginere to rebuild your machine
4/29/2014 10:47:35 AM • Kirby G5 Bagged... • Answered on Apr 29, 2014
G3 vacuum handle spring replace video kirby
see utube for fitting. however i suggest you get your local kirby enginere to do this
4/29/2014 10:43:49 AM • Kirby G5 Bagged... • Answered on Apr 29, 2014
Kirby G5 Bagged Upright Vacuum Logo
261 questions posted
Top Kirby Vacuums Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Kirby Vacuums
  • Kirby Vacuums
Most Popular Question
carpet shampoo system
  • Vacuums
