20 Most Recent Kirby Generation 3 Bagged Upright Vacuum Questions & Answers
plug it in
Kirby Generation... | Answered on Feb 20, 2019
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Kirby model by clicking the link below.
http://kirbywhq.powweb.com/manuals/Gen3/660ED597CB31973F693F1DBDFF0E4F72/Generation%203%20Manual.pdf
You can purchase a wide variety of high quality Kirby replacement parts for your Kirby vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Kirby
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Kirby Generation... | Answered on Dec 08, 2017
There may be an internal electric problem. It would suggest having it looked at by a qualified technician.
Kirby Generation... | Answered on Nov 22, 2017
Your handle lock is mostly likely stuck. I had the same thing happen to me. I tried to see if there was any videos that could help me but, there was none. Well, I notice that metal bar was sticking out at one end. So I place a flat screwdrew or in my case crowbar with that flat in one side, I placed that side of end that metal thing stick out and just hammer back inside. That's it.
Kirby Generation... | Answered on Jun 16, 2017
A hot wire is hitting the frame. Unplug it take your time and remove the housing around the motor and you will find the stripped wire. Cover it with GOOD electrical tape and you should be all set
Kirby Generation... | Answered on Apr 29, 2016
No - the silicon is an insulating material and would have no effect on the electrics of the vacuum. Most likely you have a bad connection - dismantle the vacuum again and check the wiring and the motor with an ohmmeter. Be very attentive with the brushes, if they don't sit perfectly on the collector the motor will not run.
Kirby Generation... | Answered on Jan 03, 2016
To place the kirby G4 into gear - out of Neutral - just press down with your foot, the Gray & Green lever that is labeled N on the left side of the lever, which is gray, and D on the Right side of the lever which is Green (probably for GO). It is located directly below the Power button.
Good Luck
See Pic...
Kirby Generation... | Answered on Mar 17, 2015
If you are unsure on how to splice the cord back together it may be best to just purchase a new cord. You can find a new G6 cord and it is easily installed into the switch at the base of the Kirby.
Kirby G6 Power Cord
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
Kirby Generation... | Answered on Oct 15, 2014
The belt could be old and worn out. Or if you have a high pile carpeting or fibers wrapping around the brushroll, these cause friction and when it gets hot enough it will melt either brushroll ends or belt. You can limit this by removing the brushroll and removing the fibers and hairs that wrap around the brush. You can also find a new belt here.
www.goodvac.com
1-800-775-6586
I would take it in to a vacuum service center. I had a similar issue and they restored the Kirby back to new for $100, it's been running fine now for 2 years!
Kirby Generation... | Answered on Sep 15, 2014
This will "fixya" right up!! :0)
you will need kirby engineer to fix this. contact your local agent or see kirby.com
Kirby Generation... | Answered on Apr 29, 2014
cam neutral button worn, contact your local kirby agent for service or kirby.com
normally its the field wire that goes first, needs visual inspection,
cant test power switch,so will have to test with new one
belt will be stretched fit new gen kirby belt, copy belts are not worth fitting
Kirby Generation 3 Bagged Upright Vacuum Logo
213 questions posted
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Kirby Vacuums
  • Kirby Vacuums
Most Popular Question
green light
  • Vacuums
