20 Most Recent Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Questions & Answers
Hi All
Up Date on shark no steam no light.
The fuse that controls the steam is a thermal fuse, 192c ,10 am 250 volt.
Now that may sound strange to some one who dose not know fuses, but Radio Shack carries them and there $3 bucks!
If there is a handy person you know, they should have no problem replacing the fuse. I just fixed ours in about 30 min. but I work on electronics. If the Shark gets to hot this fuse will blow to prevent overload or fire so don't put bigger fuse in it!!
FYI you have to take All the screw out and open up the unit fuse is burried look for yellow clear film (thats the color mine was), the film is wrapping the fuse. Good luck
Euro-Pro Shark... | Answered on Aug 23, 2019
Well first off, I would not recommend using any time of steam mop on unsealed or natural wood floors. They will damage them because of the heat and moisture. If your wood is sealed then it would be okay for short amounts of time. meaning not keeping it in one position on a section of your floor for a long period of time.
Steam mops are not meant to Shine floors. They are meant to sanitize and disinfect. yes they do clean as well but if your floor is shiny after use then there is to much water coming out and not enough steam.
Euro-Pro Shark... | Answered on Jul 23, 2019
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
jr
Euro-Pro Shark... | Answered on Jun 12, 2019
Problem: mineral dleposits. Just fixed mine.... DO THIS OUTDOORS. Add 1/2 c CLR to the tank, let sit for an hour, turn on, allow to heat and pump. May have to refill with CLR and repeat. Be persistent, and eventually you'll blow out a wad of dissovled minerals followed, happily, by billows of steam. Again, do this outdoors and keep the mop pointed away from people, plants and things. (I aimed mine into a cardboard box.) Follow up with a couple of tanks of water and pump until empty to clean out any residual CLR and loosened deposits. (I continued to get some black precipitate through the first water cleaning.) I will add that I began this process first with white vinegar, then with Lime Away..no luck put perhaps I was not sufficiently persistent. Or perhaps it was the sequence of attempts. (Also, do not take off the mop head...the part to which you attach the pads...it's tough to get off, does not allow access to parts that need cleaning (thought it would, not not so), and practically impossible to get back on.)
Alternatively, call Shark...they'll offer to repair for $18 plus $10+/- shipping, or may offer you a new one at "preferred customer" rate of $39.95 plus shipping. Good luck, and please remember to try the CLR outside.
Euro-Pro Shark... | Answered on Apr 20, 2019
How to disassemble shark se450
Euro-Pro Shark... | Answered on Jan 29, 2019
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";}
The heating element may have died or there is an obstruction...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
heatman101
Euro-Pro Shark... | Answered on Jan 19, 2019
Can’t get mine to change settings
Euro-Pro Shark... | Answered on Jun 12, 2018
The heating element or control is faulty.
Euro-Pro Shark... | Answered on Feb 21, 2018
The steam generator is malfunctioning or has failed.
Euro-Pro Shark... | Answered on Feb 20, 2018
-No body here know the phone number. You have to look inside your receipt.
Good luck
Mai
Euro-Pro Shark... | Answered on Jan 11, 2018
Try its factory web site.
Good luck
Mai
Hello, this is Ava with Think Crucial.
You may find the User's Manual for your Shark model by clicking the link below.
Shark S3505W Owner Manual
You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/collections/vendors?q=Shark
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Euro-Pro Shark... | Answered on Nov 05, 2017
Shark LIGHT EASY S3250 11 Owner Manual
Ava B.
Euro-Pro Shark Steam Mop - Gray/ Purple Vacuum Logo
1,522 questions posted
Top Euro-Pro Vacuums Experts
Sheldon Dedek
Mark Bowens
Mark Bowens
Are you an Euro-Pro Vacuum Expert? Answer questions, earn points and help others
View Most Popular
Euro-Pro Vacuums
  • Euro-Pro Vacuums
Most Popular Question
handle going from water reservoir handle
  • Vacuums
