That sounds like a convergence failure. The AV48WP30 convergence repair kit from www.tvrepairworld.com should solve the issue. The kit contains the components and the CD with instructions.
There is a way to reset television. I have a jvc 42inch that was just going to main logo screen and not beyond it. If i remember correctly you unplug the tv hold power button for 5 sec on tv then let go plug in and start. If that dont work unplug and then plug and hold power button on tv for 5 sec. It is 1 of those combinations. My tv worked after that. I googled my problem and a website listed that some tvs need to be reset.
Look in the owners manual for the directions on how to remove the lamp. Your model the lamp goes in from the front on the left looking at the TV. There is a thumb screw in the back on the corner holding the left front speaker on. Under the panel there is another thumb screw holding the lamp door on. You will need a Phillips screw driver to remove the lamp. You will most likely find that the lamp is bad. You will either have to order a lamp directly from JVC, a service center or a parts distributor.
From what you describe, a solder joint has probably cracked loose in a power supply or deflection circuit, which is quite common. Since you do sometimes see a good picture, all of your major components are fine. Repairing cracked solder joints is a very easy procedure and definately worth fixing on a 32 inch TV. The first 2 digits of the model number indicate the size of the TV.
Sounds like you lost the High Voltage. The beating sound is the power supply trying to start up. After a predetermined time it will quit to protect the set. This is a very common problem and typically not that much to repair. If you are not an electronics repair technician you should find a reputable repair shop and enlist their services. I would not think the cost should exceed $150.00 to repair. Good luck.
