20 Most Recent Mitsubishi VS-45607 45" Rear Projection Television Questions & Answers
I have a Mitsubishi VS-4503r. The input is locked and i don't have the remote
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Unlock procedure and to override the password lock and to set the device region free procedure of many popular brand TVs and other devices are given. Search the site by type in this key phrase "How to unlock television"; in the search box at the top left of the display window, to get gathered related posts. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one. To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have. Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites. http://homenol.blogspot.com/ http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
9/2/2017 9:28:40 AM • Mitsubishi... • Answered on Sep 02, 2017
0answers
0answers
2answers
Mitsubishi VS-4543
is that wavy in vertical motion? and bending?  in that case maybe you have low voltage in your power inlet! or can you specify the color of wave and motion, if horizontal or vertical?
2/18/2015 8:36:39 PM • Mitsubishi... • Answered on Feb 18, 2015
TV won't power on.
The Convergence ICs are bad. There is a pair of them on rather large heatsinks on the main board. If you have little or no soldering experience these can difficult to remove and replace. Not a cheap or quick fix.
12/27/2013 7:55:40 AM • Mitsubishi... • Answered on Dec 27, 2013
Purple static lines and a jumpy picture
Your picture tube is about to go. If it's still under warranty,take it back. Hope this helps.
11/26/2013 5:25:39 AM • Mitsubishi... • Answered on Nov 26, 2013
0answers
Mitsubishi vs-4507r rear projection tv. It wont
hola amigo ami me paso lo mismo pero es necesario el control para poder desbloquear si es universal el codigo es 1250y asi podras entrar al menu
11/2/2012 8:32:21 PM • Mitsubishi... • Answered on Nov 02, 2012
Mitsubishi model#VS4552A/ need to know how to access and change settings without remote
can't be done but almost any Mitsubishi remote made over the time of 10 years or so of this set will work.
10/26/2012 5:36:25 PM • Mitsubishi... • Answered on Oct 26, 2012
Television wont turn on. noticed
does the green LED light flash on/off forever? Did you try the reset button?
9/30/2012 9:04:55 PM • Mitsubishi... • Answered on Sep 30, 2012
JVC Model# HD-56GC87 runs 15mins then shuts off why? picture is bright and clear, fans all working, lamp compartment door switch ok. no timers on. what could it be??
You may want to contact JVC as I seem to remember this model did have some upgrades that needed to be done with a computer hooked directly to it.
4/23/2012 8:34:37 PM • Mitsubishi... • Answered on Apr 23, 2012
3answers
The picture on my Mitsubishi Model VS-45607 is not
Good Day,
It sounds like you have a bad cap or IC. Replace C2P05 100 ufd 16 volts, off Pin 3 of IC2P01. It is on the Signal Board. IC2P01 Part # 270P466020 (stand-up type mounted on heat sink). The Signal Board is the the board on the left hand side looking at the TV from the back. The parts are on the right side of the Signal Brd towards the middle and back. Replace it even if it checks good. Look at other Caps in the general area and if you see black stuff on the negitive leg of those caps(replace them also).
Good Luck, Big Irish.
4/23/2012 9:51:10 AM • Mitsubishi... • Answered on Apr 23, 2012
Mitsubishi VS-45607 45" Rear Projection Television Logo
292 questions posted
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Mitsubishi Televison & Video
Most Popular Question
jvc model hd 56gc87 runs 15mins shuts
  • Televison & Video
