20 Most Recent JVC AV-56WP30 56" Rear Projection Television Questions & Answers
0answers
JVC Model No. HD-61Z456 Screen is completely Green
Sounds like the green tube is shot, tap on the green board see if theres a loose connection, with something hard plastic
4/22/2014 7:58:05 PM • JVC AV-56WP30... • Answered on Apr 22, 2014
Picture is blue
HOW TO FIX MY JVC TV
12/29/2013 10:49:21 PM • JVC AV-56WP30... • Answered on Dec 29, 2013
2answers
Red, green , blue
I would guess that the top and bottom of the picture is pulled toward the center of the screen as well. This is a convergence problem. If you can solder, you should be able to repair this yourself. If you wish to attempt this repair, please update this and I will provide more details and instructions.
Thanks,
Dan
12/29/2013 10:48:37 PM • JVC AV-56WP30... • Answered on Dec 29, 2013
POWER SUPPLY
bad power slup or bad con,v ic stk392-120
11/21/2013 2:41:27 AM • JVC AV-56WP30... • Answered on Nov 21, 2013
0answers
Convergence not alighning tv screen
No you cannot! There is a switch on the convergence pnl for complete convergence. You can make things 10 times worse if you don't know what your doing.
11/3/2012 3:56:49 PM • JVC AV-56WP30... • Answered on Nov 03, 2012
Convergence wont line up
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com Common Problem #1) Convergence has gone outProjection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem. Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. The power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems. 7859b01.jpge87380c.jpg 69189a5.pngSOLUTION #1What you will need to do is convergence. You can get a repair kit from TvRepairKits.com . It includes replacement parts,step by step instructions, support, etc.Common Problem #2) CRT Fluid is CloudyProjection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images. Picture of a set that needs the fluid changed.578ba6c.jpg TV set after fluid change65af323.jpg 69189a5.pngSOLUTIONWhat you will need to do is replace the coolant and clean the crt. You can get a repair kit from TvRepairKits.com . It includes replacement coolant,step by step instructions, support, etc.
3/9/2012 3:18:29 AM • JVC AV-56WP30... • Answered on Mar 09, 2012
I cant get my convergence to line up on my tv
Your convegence has gone out. You can get complete kits with instructions from sites such as www.TvRepairKits.com or just the parts from www.ConvergenceChips.com . If you have never done this before i would suggest going the kit route since it includes step by step photo instructions and support.
3/6/2012 2:12:53 AM • JVC AV-56WP30... • Answered on Mar 06, 2012
2answers
JVC I'ART PRO WILL NOT TURN ON
hi keith, if it smokes a bit leave unplugged and get a engineer to have a look at it straight away good luckregardsshaun
11/28/2011 6:02:01 AM • JVC AV-56WP30... • Answered on Nov 28, 2011
I cannot adjust the #
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
8/27/2011 3:23:27 AM • JVC AV-56WP30... • Answered on Aug 27, 2011
JVC AV-56WP30 56" Rear Projection Television Logo
168 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
convergence wont line up
  • Televison & Video
