20 Most Recent JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Questions & Answers
Looking for circuit diagram of convergence board for resistor ratings
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ http://schematicscom.blogspot.com/ http://homenol.blogspot.com/
5/27/2017 12:46:08 PM • JVC AV-48WP74... • Answered on May 27, 2017
JVC AV-48WP30: CONVERGENCE PROBLEM!!! HELP!!!
U have convergence board issues. Sometimes over time the solder joints on the board go bad or develop minute breaks. U might try removing the board and resoldering every thing you can get it. U can also consider baking the board in an oven at around 270 degrees for about 8 minutes to melt all of the connections on the bottom of board. Then remove, allow to cool, cross your fingers and see what happens.
5/5/2017 5:18:32 PM • JVC AV-48WP74... • Answered on May 05, 2017
AV-48WP74 48 in. Rear Projection HDTV-Ready Television: my 3 colors are all out of whack and the convergen...
you most likely need to replace the convergence ICs. If you are lucky, they may have unsoldered pin connections at the PCB, you can try re-soldering those loose pins. What usually happens is that because of the heat generated, the pins have become detached at the IC also, thus the need to replace the ICs. Some of these have either fuses or resistors to the ICs that have also opened & will need replaced also.
3/4/2015 7:15:37 AM • JVC AV-48WP74... • Answered on Mar 04, 2015
0answers
Blue &yellow lines, double vision on most numbers
This means that a part is failing. Check the boards for bad connections, and bad parts. IT could be in IC that is bad too
8/18/2013 3:00:31 PM • JVC AV-48WP74... • Answered on Aug 18, 2013
What is the HDMI setup procedure for JVC
in the source menu button select the HDMI option to recognized the source signal with HDMI output.
11/26/2012 11:48:09 AM • JVC AV-48WP74... • Answered on Nov 26, 2012
Whats the part number for convergence chips on jvc av-48wp74
There are two of them that need to be replced as a set. They are both STK392-110 Convergence Ics you can get the original oem Ics from www.tvrepairworld.com they are listed under the Integrated Circuit catagory you only need the one set. They also have the convergence repair kit listed for your model under the JVC repair kits the kit has both ICs all 12 resistors and the CD with step by step repair instructions.
10/18/2012 10:20:24 PM • JVC AV-48WP74... • Answered on Oct 18, 2012
How do you fix the convergence on a 2003 42 inch big screen tv?
In the menu on the tv setup you should find a test pattern that can be displayed for converging. In that menu there may be an auto converge which is much easier. If not, with the patter up you will have to manually converge the individual guns in the tv with the back off. There are adjustment knobs or screws for focusing the guns.
10/5/2012 3:43:28 AM • JVC AV-48WP74... • Answered on Oct 05, 2012
My 48 inch jvc tv has a green color to it what can
Okay so the green color that you see on the screen is because the coolant inside of the green picture tube is gone bad (it suppose to be cristal clear but now it is brownish and that makes the green color run all over the screen.) That just happens over time and I'm guessing the picture tubes have never been serviced. Now you got two choices
1- The easiest and fastest way would be to take it to a local repair shop and have them service the coolants of your picture tubes. I'm guessing it would run you about $165 or so to get them done (the three of them red,green and blue)
2-On the other hand you can do it yourself. It is not hard at all but it does require a lot of attention.
After the picture tubes have been serviced you'll notice the big difference.
You'll actually have a much brighter and sharper picture just like when it was new.
Let me know if you decide you want to do it yourself so i can post the instructions for you.
9/3/2012 1:42:21 AM • JVC AV-48WP74... • Answered on Sep 03, 2012
Fuzzy screen everthing look's double
If its 3D looking or warped looking its a convergence failure. This is common on all projection TV sets. This video may help.
4/13/2012 8:23:09 PM • JVC AV-48WP74... • Answered on Apr 13, 2012
0answers
0answers
0answers
JVC AV-48WP74 48" Rear Projection HDTV-Ready Television Logo
Popular Tags
234 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • JVC Televison & Video
Most Popular Question
looking circuit diagram convergence
  • Televison & Video
