20 Most Recent JVC LT-26WX84 26 in. LCD HDTV Questions & Answers
Rest button on jvc 47 inch jvc flat screen tv
In order to reset a TV, just unplug. There is no menu reset option
11/26/2014 5:14:04 PM • JVC LT-26WX84 26... • Answered on Nov 26, 2014
On my jvc LT-26wx84 32 in, tv powers on screen comes on then goes pink
If connected via component jacks from a box unplug the box and set and wait---then plug both back and let them reboot--likely in this situation it is coming from the box
4/16/2012 2:08:06 PM • JVC LT-26WX84 26... • Answered on Apr 16, 2012
How do I run setup without remote
you need the remote---an original remote.
3/25/2012 3:47:47 PM • JVC LT-26WX84 26... • Answered on Mar 25, 2012
How do i connect to component cable
Component video has to be hooked up as "component" which is the red, green
11/28/2011 12:13:27 AM • JVC LT-26WX84 26... • Answered on Nov 28, 2011
Vertical Lines LCD TV. Not to sure when it started
Hi :There are two possible reasons why this is happening, one is the T-Con board has failed. And the other is the main board digital circuits is faulty. when changing resolutions the scaleing IC is probably bad, I suggest you go with the cheaper of the two parts and start with the T-Con board first, if this does'nt repair the problem then it you main board that is faulty.
9/9/2011 8:20:00 PM • JVC LT-26WX84 26... • Answered on Sep 09, 2011
My rca flat screen I can hear the sound but the
Now,the tv turn on screen panel have flashes pictures a few sec. than died and have sound left only?Yes.This problems ur tv is having,most likely the tv long LCD inverter board is dead.This long LCD inverter board job is to help the LCD screen panel to have a backlight to produced a picture.Can u do some basic machanical skills,like take things aparts and putting it back again?Yes,Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Long LCD inverter board for the replacement.
2/23/2011 11:49:17 PM • JVC LT-26WX84 26... • Answered on Feb 23, 2011
Power supply jvc lcd 26
Required power supply board for JVC LT-26WX84 is available in Shop Jimmy, click that link for price info.
Thanks.
3/16/2010 11:47:29 PM • JVC LT-26WX84 26... • Answered on Mar 16, 2010
3answers
Several smokey lines cross the screen
I probably had the same problem. The cause is a bad main board ($276+-), digital board ($225+-) or analog ($102+-) board. Labor should be about $130. The actual lcd should be fine.
JVC will only issue a recall if 1500+ complaints on a model.
2/17/2010 1:37:36 AM • JVC LT-26WX84 26... • Answered on Feb 17, 2010
JVC LT27 DF7 won't come off standby.
Capacitors don't show resistance unless you use an ESR meter. If you could give me more voltages coming out of the power supply then I can help. If you want to change a board then try "Encompassparts.com"
10/27/2009 5:45:07 PM • JVC LT-26WX84 26... • Answered on Oct 27, 2009
No picture, but sound
does it work if you connect dish??
3/26/2009 1:31:13 AM • JVC LT-26WX84 26... • Answered on Mar 26, 2009
Hey got a good one
LCD sets sometimes will not power up until the backlight boards power up. the backlight boards have SMT fuses that open. and driver FETs (commonly also SMT) that short.
check the backlight circuits first.
12/5/2008 8:15:08 PM • JVC LT-26WX84 26... • Answered on Dec 05, 2008
Black lines at top of tv
this could be a bad wirestrip or the board is going bad
11/30/2008 9:37:51 AM • JVC LT-26WX84 26... • Answered on Nov 30, 2008
My JVC 58in. Flat screen blinks?
The cable connections for your TV are not connected properly or are loose or the cables might have damage or the connection ports are broken.
12/6/2022 5:26:37 PM • JVC LT Televison... • Answered on Dec 06, 2022
2answers
The USB will not work for pausing live TV how can I fix this?
no info generic answer read owners manual or search online for one
5/14/2022 12:50:19 PM • JVC LT Televison... • Answered on May 14, 2022
JVC TV model,s avk14t3-1 has sound and no picture in audio-video mode
it needs service, that means using tools and meters and spare parts to find cause. dead screen black screened at all times.? even in HD TV antenna mode for HD TV? or just the remote CLICKER batteries dead. tell things that work and no not work , even LED actions. the maker has no books on this old TV https://jvcproducts.com/us/contact/support.html here they are ask them>? what rare TV. good luck fixing any RARE TV. moved you to TELEVISION.
3/24/2022 11:25:05 AM • JVC LT Televison... • Answered on Mar 24, 2022
TV is just over one month old - screen started getting darker and darker in pathes, now more than 60%, tried resetting all settings to default, tried all inputs (Video, HDMI, RF) all the same result -
Return it to your place of purchase and get something else anything else you wouldn't believe how many people are having Issues with the LT series get rid of it.
1/4/2018 12:22:16 PM • JVC LT Televison... • Answered on Jan 04, 2018
NO POWER LIGHT OR STANDBY LIGHT COMING ON
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electro-medical.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge)
3/10/2016 7:13:11 PM • JVC LT Televison... • Answered on Mar 10, 2016
JVC LT-26WX84 26 in. LCD HDTV Logo
26 questions posted
Top JVC Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
 Grubhead
Grubhead
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
LT JVC
  • LT JVC
Most Popular Question
power supply jvc lcd 26
  • Televison & Video
