HP DeskJet 6988 Printer Logo
A
Anonymous Posted on Mar 02, 2014
Lines on printing - HP DeskJet 6988 Printer
Ezewudo Onyekachi
Level 3:
Master:
  • HP Master 425 Answers
  • Posted on Aug 26, 2014
Ezewudo Onyekachi
HP Master
Level 3:
Master:
Answers
425
Questions
7
Helped
83542
Points
1141
I got new checks and the print is now not lined up on the lines when it prints, also, the printer does not recognize the paper
Quickbooks has a print option where you can adjust how the checks print. I have always made a copy of the blank check and adjust the settings until it prints on the line. If you keep making adjustments you can get it to print almost
perfectly.
2answers
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
4helpful
White lines running through printed line
The white lines occur when the print-heads do *NOT* output coloured-ink when they should be.
Run the Epson printer-software to "clean-the-print-heads".
Printer keeps skipping lines when printing. very annoying
is this a case of the dots are missing for a valid line, or do you mean a line feed is added at the end of a line, ie you get 3 lines of text occupying 4 lines of space , or 4 lines of text occupies 4 lines of space, but one line has no printed dots on it? to make it more obvious, what does a document with say text thats 3cm tall look like? as it sounds to me like contacts need cleaning.. *** note for info: do not rely on printouts from within a BROWSER as that may have unpredictable results. All text will be treated as a large block of PIXELS and Not TEXT. also Non Printer fonts could cause similar issues.
1helpful
Printing every few lines blurry, but not every line.
Printer head is clogged, be sure to clean it until you get the solid lines
My multipass f30 prints two lines skips a line prints two lines,
Try going to the "menu" button and look for "printer settings", then "cleaning" on the display.
ON SOME LINES OF PRINT, THE ENTIRE LETTER DOES NOT PRINT
Do a printer utility deep cleaning and possibly be prepared to replace the cartridges
2answers
Print result at 1st line ok..2nd line become blur..its alternate till end of printing
Replace the ink cartridge.
The cartridge is so wide that it can print 2 lines at a time, and the upper part of it is probably partially clogged. That's why every 2'nd line is blurred, and the rest is ok.
EPSON Stylus CX3810 thin white line in every printed line
Hi there the likely thing is that there is a small blockage in the print heads not allowing the jet to fire and causing a blank line. You could remove the print head turn it upside down using a soft cloth clean the print head also use a alcohol based fluid to aid you.
Try this if it's doesn't work then the print head will need replacing you will be able to buy online.
Thanks J
k24674
Grand Canyon Tech
Grand Canyon Tech
