20 Most Recent
HP DeskJet 6988 Printer Questions & Answers
Just bought a NetGear WNDR
Is the printer software installed on the laptops? Are you trying to print from the laptop itself, or a phone or tablet?
Sounds like from what you said the devices are on the network, but they still need the correct software to communicate with each other.
Try to use a smartphone and install the HP mobile printing app, if that app is able to find your printer, it is indeed on the network correctly.
If you can print from the phone/tablet, but not the laptops, you need to install the software drivers for your printer to your laptop(s) you wish to print from.
Here is a link to the Windows Drivers
HP Software drivers -
HP Deskjet 6988 Printer Software and Drivers
I have windows 7 and the hp deskjet 6988 wont work
your drivers and software probably dont support Win7 go to the hp website and download the latest drivers and software for your model and win7. download them install them then plug your printer into the usb port and it should find the new hardware and install the drivers for it
Color printing
Check your printer preferences and make sure the colour icon is tagged or at least the grayscale option is not tagged. Try holding the power button on and pressing the paper feed button once or three times to generate a self test page. If there is still no colour the cartridge is probably faulty.
My printer is on but
- Click Start and then click control panel.
- Select device and printers.
- Right the printer icon and select "use printer online".
HP F4140 Printer - all lights flashing, blinking E
This is a printer hardware error, you cant try below reset methods.Power Drain:1. Unplug the printer power cord from wall and the printer, disconnect USB cable from printer.2. Press and hold the power "ON/OFF" button for 30 seconds and release it.3. Connected the power and check the printer.
I have an HP 6988
I would take the cartridge out, and use a qtip with a bit of rubbing alcohol on it to clean off the contacts on both the cartridge, and the corresponding one on the printer itself. It seems as though the printer is unable to get a signal from the cartridge so it is just displaying a generic 'out of ink' error.
