SOURCE: waste ink full
This step is a "reset" step for the Canon CLI8
cartridges. The original Canon CLI8 cartridges have a memory chip on
the back of the cartridge, which sends a signal to the printer when the
cartridge is empty. Your printer won't be able to determine how much
ink is in the compatible cartridges, but you can easily monitor the ink
level by noticing the ink level drop in the cartridge as you print (the
cartridges are see-through), or by noticing low ink output on the
printed pages when you run out of ink. The "reset" procedure below is
the best procedure we know of to date to allow your printer to use
Uni-Kit cartridges which offer a tremendous savings over the Original
Canon products.
With the original chip now
attached to the compatible cartridge (you may need double sided tape to
get the chip to stick well to the cartridge), and with the cartridge
now in the printer, Press and hold the Reset/OK Button for 5 seconds to
reset the chips.
SOURCE: Error 5800: waste ink
Clean or replace the absorber and reset the printer counter to clear the message.
SOURCE: canon printer mp160 e27
how can i get my ink absorber to be unful and work agian so i can print again WANALI
SOURCE: waste ink is full how to clear this message
a) How to enter Service mode
Follow the procedure below to enter Service mode.
1) Turn off the printer.
2) Turn on the printer while holding down the [Paper Source] button and [Online]
button.
3) Check that "Canon W8200" is shown on the display, and then release the buttons.
4) Next, "SERVICE MODE" is shown on the display. (If sheets are inserted, this will
be displayed after the sheets are loaded.)
5) Use the [Lower arrow] button to make a selection.
Service mode is added to the options in the Main menu.
Service mode can be entered even during error status (when Exxxx and Wxxxx are
shown on the display) by turning the power off and then using the above key
operation.
b) How to exit Service mode
To exit Service mode, turn off the printer.
c) Buttons used in Service mode
• Selecting menus and parameters: [Left arrow] button or [right arrow] button
• Entering a lower-level menu: [Lower arrow] button
• Entering a higher-level menu: [Upper arrow] button
• Setting menus and parameters: [Enter] button
Now under service mode select counter, and select printer and W-INK to reset it, and under initialize select W-INK.
But also change the waste ink absorber so that you do not get waterfalls of ink from your plotter :-)
Hope that helps
Testimonial: "Thank you very much............ "
Eight flashes: Waste ink absorber almost full
The printer has a built-in waste ink absorber for the ink used during Print Head cleaning. Eight flashes indicates that the waste ink absorber is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink absorber becomes completely full, contact a Canon service representative.
Important
Canon recommends that you call for service as soon as this error occurs. Once the waste ink absorber becomes completely full, printing will no longer be possible
