20 Most Recent Canon i350 InkJet Printer Questions & Answers
Hi Kevmccree !!
Thank you for writing to the Fixya Forums.
This problem may have several causes:
A) Empty or almost empty ink tank(s)/ink cartridge B) Ink tank is not seated properly C) The printhead nozzles may be clogged D) The printhead may need realignment E) Printing on the wrong side of the media or the incorrect media type is selected in the printer Properties.
This is what it says on the Canon site for your printer:"Printhead alignment in Windows"
http://www.canon.co.uk/Support/System/Search.aspx?TcmUri=tcm:14-517379&Search=Canon%20i350%20Print%20Head%20Alignment&SearchType=3
Alternative Step: Go to Printers in the start menu or control panel, rightclick the appreopriate icon, and click Preferences. Now click Maintenance, and click head alignment.
I hope this solves the problem. Feel free to update me on the status.
Regard's
Anurag-MCP
Canon i350... | Answered on Dec 01, 2018
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Canon i350... | Answered on Sep 05, 2018
OK, Boys and Girls...here finally is the complete answer to the problem of the waste ink tank counter reset for Canon i250 and i350 printers.
1. Disconnect printer from AC power (take out AC cord or power off your power strip). Disconnect USB PC cable from printer.
2. Press and HOLD the POWER button (untill step 7).
3. Reconnect power cord (turn on power) to the printer.
4. The indicator should be green.
5. Press and release the RESUME button , the indicator should be orange.
6. Press and release the RESUME button again, the indicator should be green.
7. NOW Release POWER buttons.
8. NOW Connect the printer to PC (USB cable).
9. NOW...I opened "Printers" and saw that a "copy" of my printer (i250 or i350) had been made. Make that COPY your default printer and all should work...It did for me.
You May Thank Me NOW!!!!
I must say...I went into the "GUTS" of the beast and cleaned out the PADS (they are actually vacuum pads that the INK is sucked through during a HEAD cleaning) a very messy undertaking.
I'm not sure how much life this will add to your printer.
Good Luck
Canon i350... | Answered on Nov 27, 2013
can you please provide more details no what exactly is the problem?
Canon i350... | Answered on Oct 02, 2013
Step 1:
light flashing orange tried to reset but failed
Step 2:
tried to rest,but orange light still flashing
Canon i350... | Answered on Feb 25, 2013
Green and yellow is a service error, but it flashes a longer green, and then the green yellow flashes, and a longer green again. You need to count the number of yellow-greens in between the longer green flashes, to know the error code.
Canon i350... | Answered on Nov 21, 2012
Down load the drivers from the internet. Go to the Canon website and go to their support/drivers section.
Canon i350... | Answered on Apr 22, 2012
Download from here.
Canon i350... | Answered on Sep 24, 2011
download the driver from some of these sites and try:
www.opendrivers.com/categorycompany/13/129/printers-canon-free-driver-download-page6.html
printers.free-driver-download.com/canon.html
multifunction.free-driver-download.com/Canon/33451/Canon-imageCLASS-MF5730-MF5750-MF5770-Firmware-Update
www.fixyourownprinter.com/forums/inkjet/21129
scanner.free-driver-download.com/Canon/29335/Canon-CanoScan-D660U-Scanner-Driver-ScanCraft-CS-P-v5.8.2-Wi
cameras-and-mp3-player.free-driver-download.com/.../Canon-PowerShot-A60-Firmware-2.0.0.0-For-Windows.html
www.softpedia.com/?tag=dir
check for the given instruction on how to change colours
Canon i350... | Answered on Jun 27, 2011
Remove the head by removing the cartridges and lifting the leaver on the cartridge holder.
Then follow the steps in the link below.
http://www.fixya.com/support/r3986425-unblock_print_heads
Re-Install and try again.
I hope this helps, if so please rate this answer below Thank You for supporting the FixYa Community Regards GM
Canon i350... | Answered on Apr 12, 2011
Canon i350 InkJet Printer Logo
98 questions posted
Clive
Clive
old marine
old marine
View Most Popular
  • Canon Office Equipment & Supplies
Most Popular Question
canon i350 printer
  • Office Equipment & Supplies
