Kodak EasyShare P880 Digital Camera Logo
d
david johnson Posted on Feb 07, 2014
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can i update camera firmware through a printer dock?
I dont have a usb cable but have a dock the camera fits on and works but not sure if it will work to update the firmware?
J. Van
Level 3:
President:
  • Master 1,738 Answers
  • Posted on Feb 18, 2014
J. Van
Master
Level 3:
President:
Answers
1738
Questions
Helped
624654
Points
5775
Kodak does not suggest a firmware upgrade through a printer dock. Instead, they recommend using an SD card (memory card).
First:
  1. Click Download, then save the firmware file to your computer desktop.
  2. Double-click the *.exe file. When the WinZip Self-Extractor screen appears, select a folder or accept the default location, then click Unzip. The firmware file unzips to the specified folder.
  3. Note the location of the *.FW file, then close the WinZip Self-Extractor.
Instructions:
  1. If you have pictures/videos on your camera's internal memory or on the memory card, save them to your computer.
  2. Ensure that your camera batteries are fully charged.
  3. Turn off your camera.
  4. Insert the memory card into your computer or into a card reader attached to your computer.
  5. Verify that the memory card has at least 100 MB free space.
  6. On your computer, select the removable drive associated with the memory card or card reader.
  7. If a System folder does not exist on the memory card, create one. From the removable drive window, select File > New > New Folder, then name the new folder System.
  8. Copy the *.FW file from your computer into the System folder.
  9. Remove the memory card from your computer or card reader, then insert it into your camera.
  10. Turn on your camera, then follow the instructions to begin the firmware upgrade. The upgrade takes approximately two minutes to complete.
  11. When "Upgrade was successful" appears on the LCD, select Delete Upgrade File to delete the firmware file from the memory card.
  12. Turn off your camera, then turn the camera on to activate the new firmware.
3 Related Answers
miguelalvara
  • 109 Answers
  • Posted on Aug 25, 2009
SOURCE: USb Cable for my Kodak Easy Share M753 wont connect to my camera.
just buy a card reader and put your memory
card on it and download the pictures from there
thats the easy solution.
Anonymous
  • 6 Answers
  • Posted on Sep 09, 2009
SOURCE: Kodak C913 cable will not fit into camera.
Gotta be the wrong cable. Mine has a mini USB on the camera end and a regular USB male on the other. Either that or you're trying to insert it upside down. Mini USB has a long and short side.
Anonymous
  • 2761 Answers
  • Posted on Jan 01, 2010
SOURCE: Kodak Z730 no longer uploads pictures to computer
The problem that you describe indicates that your Kodak EasyShare software has somehow become corrupted. Uninstall the software (use the uninstall feature, not just delete) then download and install the current software from the kodak.com web site (this is a no-cost download). That should cure the problem, but if it doesn't I suggest that you contact Kodak customer service via their web site.
Can you update camera firmware through a printer dock
Firmware can be simply updated thru the SD card. Read the info on the Kodak site where you download the update (only update is v1.02)
Will not let me upload pics says camera not connected to usb port
The error indicates that the computer is not getting an understandable signal from the camera (or dock if you are using one). The solution will be in discovering why the signal isn't getting through, or deciding that the camera or dock is defective.
Verify that the camera battery is charged. Then turn all devices (computer, dock and camera) off. Remove every cable and wire between computer and camera. Unplug power to the dock.
Examine each connection carefully. Look for dirt, bent pins, loose connections, or anything "strange". Look at the bottom of camera too, where it sits on the dock.
Reconnect the wires and cables, power everything up and see if any improvement.
If no improvement and you have WinXP or Vista, Do a System Restore back to a date when the camera connection was working. Restart and check for improvement.
If no improvement, check computer update history. Have any Microsoft updates been applied since the last time the camera connection worked? If so back them off and check for improvement.
If no improvement or no MS updates, decide that the camera or dock are defective and return them. Unfortunately, electronics sometimes fail. If you like the camera, give a replacement a chance.
Take the memory card out of the camera and copy the pics through a card reader.
Good Luck
Nov 03, 2011 • Cameras
My HP 2840 Printer not fully functional via USB with my HP KQ752AA Docking stations (running Windows 7 32 bit), but if connected directly to the laptop it works...what is the problem w/the docking station?
Are you using the same cable to connect? The 2800 series printers do not tolerate USB cables over 10 feet and I have had some that would not connect properly unless a 6 foot cable was used. If you are using the same cable then it is possible that the drivers for the docking station are not installed properly on your laptop and you might need to update them from the manufacturers website.
Charging
USB Cable Make sure that the USB cable is properly plugged in and use the original cable that came with your player. Try a USB plug o the back of the computer. These plugs have more power available.
Computer in Hibernation mode Make sure the computer isn't entering hibernation or sleep mode while the device is connected. The computer must be ON in order to charge your player. Check you screensaver and power settings.
USB Port 2.0 Make sure the player is connected to a USB 2.0 port (1.1 occasionally causes charging problems).
Battery Make sure the battery is fully charged. It takes approximately 3 hours to fully charge the battery.
Latest firmware Depending on what Sansa player you have, make sure it's up to date with the latest firmware.
AC charger (optional) AC chargers (sold separately) have a 500-1000 milliamp max output, which provides much better charging ability than a USB port. These accessories are available on our online store.
Next try and reset the player. Resetting the player: 1. Slide and hold the Power switch up for approximately 20 seconds. 2. Release the Power switch. 3. To turn the player on, slide the Power switch up then release instantly.
Once it is back working, go to the SanDisk support site and get the updater program and update your firmware.
1helpful
2answers
Kodak easyshare cx7525 camera
are you sung a camera dock or a printer dock?
if your using a printer dock make sure the ribbon is cleared or not torned., now try to unplug/replug the power cable of the printer dock 2x, then try to print! if its failed download the latest firmware of the printer dock at kodak.com/go/downloads., then you just need to follow the instruction on the website.
If your using a Dock., the dock is not capable of printing! I hope i answered your question Gudluck!
I have a nuvi 200, less than 2 yrs old. Has probkems acquiring satelite. Has GPS sw 2.50b and audio 2.20. Also, where and how much is usb adaptor that fits to left side of unit (special plug in to unit
Acquisition of satellites has been addressed in new firmware / system software updates for the Garmin Nuvi 200W.
The usb cable you require is a standard USB to mini-USB cable. MP3 or camera cables will work.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
710c cable will not fit in new docking station
Need to buy a new USB to Parallel converter kit (is just a cable and a cd with the installation drivers) cost around $20
USB camera connection
The correct USB cable for your Sanyo VPC-C5 is part #6450752087 and you may order it from www.partstore.com
Kodak G610 prints from docked camera, but not from the computer
it is advisable to use a recomended usb cable for your printer dock. you can try also to uninstall and reinstall the printer driver on your computer. just simply follow this steps:
Remove the drivers that your operating system automatically installed on your computer:
-- On your desktop, select Start > Settings > Control Panel > Printers & Faxes.
-- Remove all Kodak printers.
Right-click the printer icon.
Select Delete.
-- On your desktop, right-click My Computer, then select Properties.
-- Select the Hardware tab.
-- Click Device Manager.
-- In the Universal Serial Bus controllers list, right-click USB Composite Device, then select Uninstall.
note: make sure that the only device connected to your computer usb port is your G610 printer dock to make sure that the USB Composite Device that you uninstall is for your G610, most of the devices connected to you usb port has USB Composite Device also.
-- In the Imaging devices list, if any Kodak printers appear, right-click the Kodak device, then select Uninstall.
-- Disconnect the USB cable from your printer.
-- Restart the computer
-- Power Cycle the printer
-- once your computer is ready connect the G610 to your computer
-- check if you have a pop up window display on your computer informing you that your computer found a hardware device
-- you can go to printer and faxes and check if the G610 printer icon is on the list
-- try to make a test print
Verify that your computer is communicating with your printer:
-- Check that your printer is on.
-- verify if the USB cable meets your printer specifications.
-- Check that the USB cable and the power cord are securely connected to your printer and your computer.
3answers
Connection Problem
I have a Kodak DX4330 and to my knowledge, do you remember if your dock or usb that you plug the camera into was plugged in when you installed the software? I think that if you have it plugged in and install the software and then try and transfer the images, it doesn't work. You can try to re-install the software and make sure the camera dock/cable isn't plugged in and if that doesn't work, make sure the little kodak symbol on the start taskbar is visible when you press the share button. i hope that this helps you.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
