20 Most Recent Kodak EasyShare M853 Digital Camera Questions & Answers
Kodak EasyShare M853. I put in a new battery but the flash won't fire. Everything else works. What can be done to fix it please?
Question translated into written English, add CAPS, fix typos and remove text speak abbreviations. Question moved to Model Category. Try this reset fix.
I have a Kodak Easy Share C513. The flash doesn't work
JustAnswer https://www.justanswer.com > Camera Problems Dec 28, 2012 - 1. Remove the battery and memory card from the camera. ... for approximately 20 minutes. 3. Reinstall the battery and power on the camera and let ... 1 answer · Top answer: It is not minor problem.If it is not under warranty then please don't send it to service ... Missing: m853 ‎' Show results with: m853
I have a kodak easyshare m753 the flash wont work
Fixya https://www.fixya.com > support > t3124129-kodak_e... Jul 15, 2009 - Remove your battery and memory card for 15 min and put them again. (you can also try by putting new batteries. In some cases battery can be ... Or camera repair near you. https://www.google.com/search?q=kodak+digital+camera+repair+near+me .
2/1/2024 5:24:45 PM • Kodak EasyShare... • Answered on Feb 01, 2024
2answers
Kodak M853 movie file doesn't play on Youtube or Quicktime player nor is it recognized by my Mac
Hello Bonita, It sounds as if the .mov file has been corrupted, I would try to format the memory card and try it again to see what happens.Hope this helps.Best Regards, Russell
11/8/2019 2:48:00 AM • Kodak EasyShare... • Answered on Nov 08, 2019
Every time I turn my camera on, it shuts itself off immediantly
Hello! Please check the "Troubleshooting" part of the manual. https://manualsbrain.com/en/manuals/1041783/?page=51 I hope it will help!
10/27/2017 10:36:12 AM • Kodak EasyShare... • Answered on Oct 27, 2017
0answers
White lines
This camera is nine years old. It is worn out. Replace it.
6/4/2017 1:48:54 PM • Kodak EasyShare... • Answered on Jun 04, 2017
19answers
Kodak EasyShare M853 Digital Camera lens error 122,1,0,0
ATTENTION:::
TO EVERYONE WHO POSTED THE COMMENTS ABOUT HOW TO FIX THIS PROBLEM I WANNA SAY THANKS. ALL I HAD TO DO WAS POP THE LENS OUT MYSELF AND THE CAMERA IMMEDIATELY WENT BACK TO NORMAL. AND NO THIS ISNT A PROBLEM WITH THESE MODELS....ITS JUS THAT WHEN THE CAMERA'S BATTERY DIES IT AUTOMATICALLY TURNS OFF AND IF U LET YOUR BATTERY GET REALLY LOW IT DOESNT HAVE ENOUGH ENERGY TO FULLY RETRACT THE LENS....WHICH IN RETURNS CAUSES THE LENS TO GET STUCK..
IN THE FUTURE JUS TURN YOUR CAMERA OFF AS SOON AS THE BATTERY LIGHT BLINKS
10/14/2016 6:39:14 PM • Kodak EasyShare... • Answered on Oct 14, 2016
How do i know when the battery is fully charged
go around the black ,shut of the car if the car don't star the battery is not fully charge but if u have a tester u got it bro
3/4/2015 10:32:37 PM • Kodak EasyShare... • Answered on Mar 04, 2015
Camera will not turn on
I have had the same problem. Can be of two things. 1) Issue with the charging circuit. When you plug your charger on it should indicate a yellow light. If not, either your charger is not working or your charging circuit is not working. Go to the store and get them checked. 2) Issue with the battery contacts. Simply take out the battery and get a cotton bud and clean the battery contact both on the battery and inside the battery compartment. 3)Issue with the charging circuit and the internal circuitry. You will have to take it to the KoDAK store. I would recommend buying a new one.
5/11/2014 1:13:37 AM • Kodak EasyShare... • Answered on May 11, 2014
Upload to computer
The best way to transfer pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa ( http://picasa.google.com ).
3/4/2014 6:51:07 AM • Kodak EasyShare... • Answered on Mar 04, 2014
Could i over charge my camera
Normally you don't over charge a battery, when it is charged for some extra hours. The electronics should stop the current. And when your computer is still working it should not have killed your camera. But be aware that as long as the camera is attached to a computer or a charger you can't switch it on. Depending on how old your battery is and how it is used in the past, the battery could be gone. But it is not only to blame on the last charge cycle. Try measuring the voltage of the battery with a multi meter. The voltage should be a few tenths of a vat above the voltage printed in the battery. I think your battery will be like 3,7 volt, and when charged the multi meter should read 4 volt. Anything below 3,7 volt means the battery is dead. (at least not fit for your camera) It is better and safer to charge the battery on an external charger in the future.
1/7/2014 10:51:06 PM • Kodak EasyShare... • Answered on Jan 07, 2014
0answers
2answers
These are family photos accidently deeted by my
What sort of media? SD card? There are many undelete utilities and services out there. Pick a reputable source like cnet.
e.g. http://download.cnet.com/Undelete-SD-card/3000-2242_4-201454.html
Install software and card and run the undelete software.
7/29/2013 9:49:13 AM • Kodak EasyShare... • Answered on Jul 29, 2013
Camera won't charge
sometimes the charger can become loose in either the camera or the plug so try buying a new plug and if it still doesn't work then it is a problem with the camera and you will have to ask the people you bought it from
6/18/2013 9:42:21 PM • Kodak EasyShare... • Answered on Jun 18, 2013
3answers
Kodak easyshare m853 digital camera
is the light that's coming on green or red?
if it's red, there's a charging error - contact kodak, they may provide a 5v ac adapter to resolve your charging issue
if it's green, was it blinking or solid? is the battery drained?
if the battery still has a little charge on it, please connect it to the computer then turn it on, check if there's power light
check if the screen is black - that means it's making a connection and the charging is the only issue - computer not detecting it, maybe resolved by kodak's software support
if the camera screen is active - that means there's definitely something wrong with the camera
arrange repairs with kodak, include the battery and usb cable
please visit
www.kodak.com/go/itg - troubleshooting and repair
www.kodak.com/go/usbcharging
6/7/2013 9:49:47 AM • Kodak EasyShare... • Answered on Jun 07, 2013
I have a Kodak Easyshare M853 and the LCD doesn't show the picture you are taking.
main board problem or related signal error.
1/25/2013 12:29:12 AM • Kodak EasyShare... • Answered on Jan 25, 2013
My kodak m863 wont turn on and wont charge wiith the usb. it doesnt have a warranty either. what should i do?
The repairs will cost more than a new camera !!
1/25/2013 12:07:01 AM • Kodak EasyShare... • Answered on Jan 25, 2013
USB cord, or reciever on camera is defective
Send it in for service with the rest of these models, lots of problems.
1/24/2013 10:38:30 PM • Kodak EasyShare... • Answered on Jan 24, 2013
Kodak EasyShare M853 Digital Camera Logo
280 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
camera wont turn after plugging wrong
  • Cameras
