20 Most Recent
Kodak EasyShare DX7590 Digital Camera Questions & Answers
How do i install a new sd card
Installing a new SD card is as simple as pulling the old one out and sliding the new one in. You may need to "format" the new card, using the camera's menus.
Kodak DX7590 won't format sd card
Usually means the card is bad. Confirm it won't do _any_ cards. Then it's a problem with the camera, and it will be a circuitry issue... not easily repaired.
Scratch in lens
Although it is annoying when you see a scratch, most scratches can't be seen on a picture. Unless it is very deep and in the centre. The only problem is, you easy can get a lens flare.
If you can live with the scratch, forget that it is there and only avoid light shining on the front lens from the side. My DX7590, still has a perfect lens, but I can't shoot, because my mode dial and joystick don't work any more. I still enjoy the pictures I took with that camera.
Kodak dx7590 camera dock will not light up
Although you did not mention what Dock you are using, I assume it is the Camera Dock 6000. Is the Dock connected with the power supply? Because only connected to the PC with a USB cable will not be enough. Also the LiIon battery in the camera, should be charged at least once. If the battery is completely empty the dock will have trouble to. The dock can be used to charge your camera. Then the lights should indicate the state of the battery. And the Dock can be used to transfer pictures to the PC. But before that will work correct you have to install the software that came with the camera. (Easy Share software)
Flash doesn't pop up
If you move the switch on the right of the flash, to the right, the flash still won't come out? That is how I have to open my flash on my DX7590
