20 Most Recent Kodak EasyShare DX4900 Zoom Digital Camera Questions & Answers
Well used DX4900 Fuzzy pictures
Repair would far exceed the cost of replacement. It has been a loyal servant over many years - it should now be retired and replaced by a newer model.
7/26/2017 10:44:38 AM • Kodak EasyShare... • Answered on Jul 26, 2017
Can't find software download.
You don't need the Kodak software.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
12/15/2012 8:24:35 PM • Kodak EasyShare... • Answered on Dec 15, 2012
You don't need the Kodak software. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
12/15/2012 8:23:42 PM • Kodak EasyShare... • Answered on Dec 15, 2012
I dont have the disc to download onto my computer
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Picasa ( http://picasa.google.com ).
5/27/2011 9:12:11 PM • Kodak EasyShare... • Answered on May 27, 2011
I just purchased a used
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program, such as Windows Photo Gallery or Picasa ( http://picasa.google.com ).
5/14/2011 12:18:08 AM • Kodak EasyShare... • Answered on May 14, 2011
Kodak EasyShare DX4900 E13 error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
9/30/2010 7:05:44 AM • Kodak EasyShare... • Answered on Sep 30, 2010
My camera len will not extend or extract and makes
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
5/21/2010 7:17:32 PM • Kodak EasyShare... • Answered on May 21, 2010
Lens won't zoom in and out
There is no firmware available online for this camera model. Therefor there is no solution for this issue.
Due to lack of spear parts for this particular model KODAK no longer repairs this model.
KODAK also offers a Trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
In order to arrange your repair/Trade up: Contact KODAK:
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
1/7/2010 11:53:07 AM • Kodak EasyShare... • Answered on Jan 07, 2010
There is juice going to
If I'm not mistaken only KODAK rechargeble batteries are suitable for this docking station. Please follow the link to the recommended batteries:
http://www.kodak.com/global/en/service/batteries/batteryDigCamChart.jhtml?camera=DX4900
12/15/2009 4:11:14 PM • Kodak EasyShare... • Answered on Dec 15, 2009
My kodak DX4900 just completely locked up and wen
This is a lens error. KODAK suggests a repair for this fault.
However due to spare part shortage this model is no longer repaired. Instead KODAK offers a trade up option where you will have the opportunity to trade up to a newer model 25-30% cheaper than the market price.
Contact KODAK:
12/7/2009 9:06:33 AM • Kodak EasyShare... • Answered on Dec 07, 2009
The battery will not hold its charge after
sounds like charger or adapter is faulty does the light stop blinking?
11/16/2009 10:22:43 PM • Kodak EasyShare... • Answered on Nov 16, 2009
2answers
My Kodak DX4900 lense will not retract when I turn
This is a list of the error codes, obviously some aren't of much help but ...
E1 The memory card is not compatible with the DC50 Zoom Camera. Use a compatible card. E10 Take the camera to your dealer for service. E11 Take the camera to your dealer for service. E12 Take the camera to your dealer for service. E13 Take the camera to your dealer for service. E14 Take the camera to your dealer for service. E15 Take the camera to your dealer for service. E16 Take the camera to your dealer for service. E17 Take the camera to your dealer for service. E20 Reseat the memory card.
or
Replace the memory card with a known good card.
or
Take the camera to your dealer for service. E21 Confirm that the memory card is compatible with the camera.
or
or
or
Take the camera to your dealer for service. E22 Reseat the memory card.
or
or
Take the camera to your dealer for service. E23 Confirm that the memory card is compatible with the camera.
or
Take the camera to your dealer for service. E24 Confirm that the memory card is compatible with the camera.
or
or
Take the camera to your dealer for service. E25 Confirm that the memory card is compatible with the camera.
or
or
10/12/2009 12:48:26 PM • Kodak EasyShare... • Answered on Oct 12, 2009
Battery door replacement
hi,
you must be contact kodak servise center,and if you have the same door then first remove the scruve near by cell door then put some presure on it for remove the body you must be find that now you can change it easily
8/31/2009 5:48:55 PM • Kodak EasyShare... • Answered on Aug 31, 2009
When i turn my Digital Camera Kodak EasyShare DX
Remove the batteries and clean the battery contacts inside the camera with a soft cloth (a heavy buildup on the contacts may require cleaning with a fine wire brush, steel wool, or sandpaper). Remove any residue that the cleaning leaves in the camera, and then reinstall the batteries. This clears most power-on problems, but if yours persists, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
8/16/2009 3:04:15 PM • Kodak EasyShare... • Answered on Aug 16, 2009
Our docking unit is not charging the batteries
It could be a charger problem, or a battery problem (or even an AC adapter problem). If you're sure there's "juice" getting to the dock, the actual batteries are usually the culprit.
8/11/2009 2:54:26 PM • Kodak EasyShare... • Answered on Aug 11, 2009
I bought a 4gb memory card and it starts to format
Try to format it using a card reader from a computer, instead.
7/5/2009 1:04:55 AM • Kodak EasyShare... • Answered on Jul 05, 2009
E13 error code
services is costing high better buy canon or nickon cam
6/18/2009 11:52:34 AM • Kodak EasyShare... • Answered on Jun 18, 2009
3answers
Connection Problem
I have a Kodak DX4330 and to my knowledge, do you remember if your dock or usb that you plug the camera into was plugged in when you installed the software? I think that if you have it plugged in and install the software and then try and transfer the images, it doesn't work. You can try to re-install the software and make sure the camera dock/cable isn't plugged in and if that doesn't work, make sure the little kodak symbol on the start taskbar is visible when you press the share button. i hope that this helps you.
10/17/2008 2:47:46 AM • Kodak EasyShare... • Answered on Oct 17, 2008
Kodak EasyShare DX4900 Zoom Digital Camera Logo
26 questions posted
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
View Most Popular
EasyShare Kodak
  • EasyShare Kodak
Most Popular Question
39 t find software download
  • Cameras
