20 Most Recent
Kodak Easyshare M580 Digital Camera Questions & Answers
Why do pictures "smear" on my Kodak camera? It is fully charged and new battery
Because with a digital camera you need to stay still a beat longer than you do with film. I usually tell folks to count 1.-2. Whentaking a photo. Press the button to activate your shutter, count two. Then move and i bet your ' smear' disappears. It is basically needing time to write the photo before you move. We are all used to film which only captures ligt on chemicals . Once and done. With digital we need to give the mechanics a tiny bit more time to finish. Hope that helped
Kodak M580 digital camera pics do not have accurate colors.
I have seen color problems on cameras that have a physical switch to change between manual settings and auto. Whenever I see the color change, I immediately look to my camera and flip the switch back to the auto position. I.e. be sure your camera is set to auto for camera settings.
I hope that helps someone.
My camera wont power on
It sounds like your batteries are dead? Try new batteries and if it still won't turn on you will need to contact a repair shop.
Transfer desktop
Many laptops come with a card reader built-in. For machines that don't, a card reader can be purchased for not much more than the price of a cup of coffee.The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa (
http://picasa.google.com ).
Will not start
These models have recurring problems, needs service/repairs.
My kodak m580 fell realy hard an would not *** on
Without looking at it properly it would be hard to tell, but it sounds like you have broken one of the plastic guides or runners inside. Unfortunately you are best taking it to a professional to see if it is repairable.
