20 Most Recent
Sanyo VPC-C5 Digital Camera Questions & Answers
My IBM computer doesn't recognize
Welcome to Fixya
Did you accidentally dropped the camera? You should be able to see options when you plug in the camera to your computer. Try to reset the camera first to factory state as part of our initial troubleshooting.See procedure below:
Select reset settings icon
Press set button
Reset setting screen should appear then press YES
Press the SET button
Camera setting should be reset then test the issue again
Thank you for using Fixya!
If you need further help, reach me via phone at
https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
SDHC Cards
Sorry, what you ask is impossible. SDHC compliant devices contain different hardware and no amount of firmware can overcome that limitation.
I have a sanyo vpc-t850 camera and looking for
The sanyo does not need any drivers, plug it in your computer with usb, turn camera on, select "PC" and press the SET button. now your camera will show up in my computer or computer as a removeable storage device and inside you will find the pictures.
I have the same camera so I know this is how its done.
Sanyo VPC-T850 Camera. Came with
I have installed all the software on the disc that came with the camera. Connected the camera to the laptop and the laptop will not recognise. I have photo on the camera I would like to download but cannot!
Help
dear sir
if it's do veruse time just chande yr USB cable or use different usb port after use the sectuation u face same problem chek virus may be yr system is inficted with Trojen or antispy..
dear sir
u have a drvier cd with phone give u when u perchase that phone and when u connect your phone to pc it's show SamsungD900i found then u give path from yr drvier cd it's depend whitch OS u company give all most OS drvier built in CD u have to install software first which also located in CD then connect yr phone to pc as my sujjaction first install full softwre and drvier after connect yr phone to yr Pc and if u allready connect yr phone just plug out then install software and drviers after finesh installaction restart pc then connect yr Phone to OTHER USB prort. it's help u..:)
Thanks
Please vote
jo_Chinmay
My sanyo vpc-c5 digital camera won't turn on
If you already tried a new battery, I would suggest cleaning the battery terminals with alcohols and a q-tip first and check for loose terminals. It may be a power switch which unfortunately can't be changed or fixed by the average user. If you want to trouble shoot further and feel you can do it yourself, I will send you links on repair. Otherwise it should be brought in to a reputable repair shop.
Deleted photos
Recuva (pronounced "recover") is a freeware Windows utility to restore files that have been accidentally deleted from your computer. This includes files emptied from the Recycle bin as well as images and other files that have been deleted by user error from digital camera memory cards or MP3 players. It will even bring back files that have been deleted from your iPod, or by bugs, crashes and viruses!
- Put the memory card into an USB card reader and plug it into the USB port in your computer, then run the Recuva program.
- Simple to use interface - just click 'Scan' and choose the files you want to recover
- Easy to use filter for results based on file name/type
- Simple Windows like interface with List and Tree view
- Can be run from a USB thumb drive
- Restores all types of files, office documents, images, video, music, email, anything.
- Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
- Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
- Restores files from external ZIP drives, Firewire and USB Hard drives
- It's fast, tiny and takes seconds to run!
Go to these WEB sites to down Recuva
http://download.cnet.com/Recuva/3000-2242_4-10753287.html www.filehippo.com/download_recuva
5/7/2014 11:02:54 AM •
Sanyo VPC...
Answered
on May 07, 2014
Sanyo VPC-S770 view screen & pictures have a rosey tint
There is only one thing I can think of. If it is not this perhaps your camera is defect.
Your camera has a White balance setting. You can put it in Auto, Incand. Daylight, cloudy and Manual.
Check if it is in something other than Auto. If so, put it in Auto, till you think you can improve the colours by putting it in a special setting.
1/29/2014 1:58:33 PM •
Sanyo VPC...
Answered
on Jan 29, 2014
