Janome 6019QC Mechanical Sewing Machine Logo
e
efi green Posted on Dec 26, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The needle is stuck in the up position and will not move down
Alphonesrani
Level 2:
Champion:
Habit-Forming:
  • Expert 201 Answers
  • Posted on Dec 26, 2013
Alphonesrani
Expert
Level 2:
Champion:
Habit-Forming:
Answers
201
Questions
0
Helped
38276
Points
329
Please go to mechanic shop or check the timing. And adjust the stitch normal tenstion.
Bernina 880 hand wheel stuck
I`ve had it when my needles jammed...hence locked up the machine...only thing to do is a pair of wire cutters break the needle and re assemble
1helpful
Stitch selector knob on bernina 600, not Deco, is stuck and cannot select needle position, However the width of stitch part of the knob is working.This knob has 2 parts, needle position and width control
Your machine (Bernina 600 Record) has most likely frozen (seized) due to lack of regular maintenance. Don't panic. It can be fixed with a lot of elbow grease, good quality oil and a hairdryer. The following method has resurrected several Berninas I've picked up as "nonworking."
How can fix stuck needle bar on my Bernina 730
Wheel on right side that controls the needle up and down is very tight...
It was working now it seems to be frozen the needle part wont move
Needle is stuck in down position and manually the wheel won't move
Try removing the bobbin case. Usually the thread is holding the needle in place, therefore the hand wheel will not operate. Once you get the thread released, it should all come free.
Needle stays down, will not come up.
sounds like the machine froze up, machine needs to be serviced
Main motor lock, inappropriate needle position, after broken needle
The broken needle may be lodged in the bobbin housing. If you cannot locate, take it in for professional servicing. You may have put the timing out of whack.
The needle threader is stuck down on my Emerald 116
Typically the threading device moves downward and then rotates sideways. Which function is stuck? Is the shaft bent? In any case, the threader apparatus is removable. If you need help disassembling, get a service manual for that model (probably about $20 on the internet).
My janome 11000 memorycraft's needle threader has jammed in the down position and cannot be moved
Thanks to floraq803, we have our 11000 working again. The needle threader was stuck in the down position. We turned off the machine, and turned the wheel (which controls where the needle is) until the needle threader bar was straight (approximately 1/2 way between the needle being all the way down and all the way up). Turned on the machine and the threader came back up again. Now back to sewing.
Wheel won't move
it's possible that something has come loose or broken, it needs to be serviced
1helpful
Top Janome Sewing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
