20 Most Recent
Euro-Pro 9130 Sewing Machine Questions & Answers
My foot pedal won't stop the machine from running when I release it.
I just fixed a Bernina foot pedal with this problem. There is a metal piece that presses down on a small switch when the pedal is released. The switch wasn't being pressed down hard enough to completely disconnect the power. As a result the machine kept slowly sewing when the pedal was released. I bent the metal piece down slightly with needle nose pliers so the switch would be fully pressed when the pedal is released. The hardest part was opening the foot pedal because there were no visible screws. I used a flathead screwdriver to pry the base off the foot pedal at the pivot points.
Why won't this machine work
Bobbin case might be jammed in an odd position or thread is locking mechanism and wont move hence "the buzzing" sound
Janome sensor craft 7001 helping book
if your looking for a manual here are some sites to trycheck with Janome website first or contact a Janome Dealersewingpartsonline.comsewusa.comsew4less.comsewvacdoctor.com
Wheel won't move
it's possible that something has come loose or broken, it needs to be serviced
