SOURCE: My AOC LCD MONITOR on
Press the left and right buttons on the monitor (simultaneously) while you turn the monitor on.
This should unlock it for you, this also works in reverse
SOURCE: My monitor is of AOC " e2043Fsk " . When I try
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
SOURCE: OSD LOCKED.
OSD probably refers to on screen display. and since the error message specifically states Windows XP you can eliminate anything that is not running Windows XP as the OS so likely suspect is #1.
