20 Most Recent
AOC LM742 17" LCD Monitor Questions & Answers
I just switched my monitor to another computer and
the second pc probably has different settings on video card. go to display in control panel to adjust resolution and/or colors. remember all video cards are not the same. some have more memory and capabilities than others. some are just made better and age holds a factor.
The model number on my monitor is tft19w80ps it's
Don't know about the 5- minute pop-up, but this is how you get it back to english:
- Turn the monitor on, connect a VGA cable and make sure it's receiving a signal.
- Press "MENU"
- Press "> Speaker +" repeatedly to get to the globe icon, and press "MENU"
- Press "> SPEAKER +" repeatedly to get to "English" and press "MENU"
- Press "AUTO" to quit out of the menu.
Need to buy a power cord to replace the original.
Modern monitors and desktop computer use universal power cables, so you should be able to go to an office supply store like Staples or Office Depot or an electronics store like Best Buy and ask them for a monitor power cable. It will have a three-prong end to plug into the wall and a six-sided end with three recessed slots to plug into the monitor.
If you want to buy online, monoprice.com has grest prices on cables.
Good luck.
What is the other input
The traditional (blue) connection is VGA and the other connection (which is white) is a DVI connection. It stands for Digital Video Interface. If you have an HD monitor and you are just using the (blue) VGA connection on the monitor and on the video card, you are not actually viewing in HD. On the other hand if you use the DVI connection with a DVI cable you will be viewing in HD and should notice the difference in the quality of your picture
When turned on, it immediately turns off after about 5 secs
Sounds like it could be that the lcd is going bad in your monitor. Try hooking up a known working monitor to your computer and if you get the video to stay on then you know the original monitor is bad. If you cant' get the video to stay on even with the known working monitor then you know that the video card inside of the computer is bad.
IN THE SCREEN APPEARS FREQUENTLY THE BRIGHTNES
clean the monitor by vaccum cleaner after opening and check if the front panel switches are faulty. if so replace it
it may possible by overtight of screw. there is also another reason for that is the microcontroller chip is faulty replace it .it may reprogrammed
AOC F22 lcd 22
Hold down the power button to turn it off, then hit the power button and immediately hold down the left side of the ring. Wait for the OK to disappear.
Took me a couple tries, but it works.
