SOURCE: brand new honda lawnmower starts and runs fine then backfires
There should be 1 or 2 screws on the carb. You will probably have to remove the air breather to get to the screw(s). I've been seeing a lot of these types of questions, new equipment not running properly. Factory settings were not set properly.
When you find the screw(s), screw in a clockwise direction until it stops; DON'T SCREW DOWN TIGHT, JUST UNTIL IT STOPS. Then unscrew counter clockwise 1 1/4 turns. Try starting.
Continue this process, 1/4 turn at a time up to 2 1/2 full turns. If you forget where you are at on the turning process, start over by screwing back down. Then pick up process where you left off.
If you need further assistance, just let me know.
Jim
SOURCE: I have a Honda GCV 160 LAWNMOWER IT WILL ONLY RUN
BEFORE you go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, runs for 10-30 seconds, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers ---- http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
SOURCE: My Honda GXV 160 is
Before you spend time and money on Buds solution I had exactly the same symptom .If it starts first pull when the engine is warm it is not a fuel or spark problem ,it will be the choke,on mine when the choke lever was full on it did not opperate the choke enough as the cable goes to choke it turns the metal bit clock wise but the metal choke will bend over time and will not be opening the choke just carefully bend the metal bit with some pliers so when the cable is on choke it now actuly opens the choke,it will now start first time when cold ,try this first before you strip apart the carburetor,I liked buds solution may be you might like mine ! www.distinctivehomeimprovements.co.uk
PLEASE RATE THIS REPLY FOR ACCURACY
http://repairhelpcenter.blogspot.in/2012/02/car-will-not-move-when-in-gear.html
transmission sticks in first gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-transmission-sticks-in.html
Transmission not engaging in first
gear?
http://technoanswers.blogspot.com/2012/01/mercedes-benz-not-engaging-in-first.html
Vehicle only goes
in First gear?
http://howtobyme.blogspot.com/2011/11/chrysler-pt-cruiser-only-goes-in-first.html
Car is stuck in park
and the shift will not move?
http://howtobyme.blogspot.com/2011/08/car-is-stuck-in-park-and-shift-will-not.html
Engine will not go out of park mode?
http://technoanswers.blogspot.in/2012/02/2002-nissan-sentra-will-not-go-out-of.html
Car stuck in park?
http://technoanswers.blogspot.in/2012/02/nissan-sentra-stuck-in-park.html
Car will not come
out of Park?
http://howtobyme.blogspot.com/2011/11/car-will-not-come-out-of-park.html
Automatic
transmission will not go into high gear?
http://howtobyme.blogspot.com/2011/11/automatic-transmission-will-not-go-into.html
Car wont downshift
sometimes?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-downshift-sometimes.html
Transmission
will shift into drive?
http://schematicsdiagram.blogspot.com/2011/12/buick-park-avenuetransmission-will.html
Auto wont shift
from park?
http://schematicsdiagram.blogspot.com/2011/12/ford-taurus-wont-shift-from-park.html
Car Transmission
will not go into Park mode?
http://schematicsdiagram.blogspot.com/2011/12/car-transmission-will-no-go-into-park.html
Shift indicator
directly goes to 2nd when key is turned ON?
http://schematicsdiagram.blogspot.com/2011/12/shift-indicator-directly-goes-to-2nd.html
Third gear missing
and engine losing power?
http://schematicsdiagram.blogspot.com/2012/01/third-gear-missing-and-engine-losing.html
Vehicle has whining sound in gear?
http://technoanswers.blogspot.com/2012/01/chevrolet-silverado-has-whining-sound.html
Hard to shift gears on Manual
transmission?
http://technoanswers.blogspot.com/2012/01/hard-to-shift-gears-on-manual.html
Car hard shift at slow speeds?
http://technoanswers.blogspot.com/2012/01/car-hard-shift-at-slow-speeds.html
Automatic transmission shift lever
hard to move on cold mornings?
http://technoanswers.blogspot.com/2012/01/automatic-transmission-shift-lever-hard.html
Gear shifts hard?
http://schematicsdiagram.blogspot.in/2012/02/2000-nissan-maxima-shifts-hard.html
Vehicle noticed sluggish
delayed shifts while driving?
http://schematicsdiagram.blogspot.in/2012/03/vehicle-noticed-sluggish-delayed-shifts.html
This will help.
Thanks.
