20 Most Recent RTO Automatic Transmission And Engine Oil Pressure Tester Questions & Answers
I have an meec tools gasoline generator (740-036)
before you go out and spend big money have you check the low oil switch for operation. If the sump oil is not at the correct level then that switch turns off all ignition power.
3/13/2016 8:47:12 AM • RTO Automatic... • Answered on Mar 13, 2016
My Nissan Maxima 2001 revs are high all the time on and off overdrive? Took car in to workshop within 2 months of the repair my car is not humming like it was????
Check your vaccuum hoses. They may be cracked and or have cracked tubing mounts.
9/17/2015 12:08:53 AM • RTO Automatic... • Answered on Sep 17, 2015
2001 Hondz Accord EX has a big shifting delay in the auto transmission shifting from 1st to 2nd gear
run the fault codes and look for a servo/solenoid problem for 1-2 gears.
5/5/2015 12:17:10 AM • RTO Automatic... • Answered on May 05, 2015
2answers
I need help to find a wire diagram for my Cushman struckter #898474 gas
This might help? http://www.vintagegolfcartparts.com/gallery/categories/Cushman/Cushman_Wiring_Diagrams/media/CushmanGolfsterModel735.jpg
2/26/2015 5:41:44 AM • RTO Automatic... • Answered on Feb 26, 2015
WHAT DOES CODE P0725 MEAN?
P0725 - Engine Speed Sensor Input Circuit Malfunction Read more: http://engine-codes.com/p0725.html#ixzz3R3eFacV6 and here for several care makes: P0725 Engine Speed Sensor Input Circuit Malfunction
2/7/2015 11:31:30 AM • RTO Automatic... • Answered on Feb 07, 2015
Why wont the car move when i put it in drive
Maybe you need some kind of belt on your gear box.
1/28/2015 3:20:06 AM • RTO Automatic... • Answered on Jan 28, 2015
2answers
My 2005 Ford Freestar was making a slipping noise, so I took it to Ford. They said the major component in my transmission isn't working and I need a new transmission. Ford said they would charge me $6
REbuilt Transmission for Ford should be At MAX $3.000. And add another $500 for the 6 Hours it should take to install "Ford Time"... OR go to a normal Trans shop and pay $2000 or less and that Should include the Install.. However What is the Trans Actually Doing? Is the Overdrive light Flashing?? AS for the Axle, Autozone wants under $100 for the Axle And if You want NEW I'm sure I could get it for you for less then 500 and the install for most people are around $150.00 ... You are being Taking for a Long Hard ride.. Don't do it.. :) Find someone else for Proper Costs...
1/27/2015 2:19:58 PM • RTO Automatic... • Answered on Jan 27, 2015
2001 L300 V6 won't shift out of park. Brake lights work. ????
Hi jeff If your car cannot shift out of park, have some one monitor the brake lights for you, or if you are alone, put something on the pedal and walk around back. 1) If the brake lights are NOT on when the pedal is depressed, the sensor/switch which turns them on, and also opens the shift interlock, is not functioning because a) it is broken, b) it is dirty or c) it has become disconnected. 2) If this is your problem, get your head under the dash (move the seat back and sit in it like Neil Armstrong, bring a flashlight). There are three plastic push pins holding the bottom of the dash in, remove them and place in a safe container. Remove the lower dash cover, also remove the plastic hose for the heating A/C... it comes right off, no problem. 3) Look at the pedal, there are two switches. The one closest to the door is the offender. Sometimes wiggling it will cause it to operate, but without replacing it, you will not have brake lights... so don't do this just to get on the road, you may get rear ended. Twist the switch and pull it out. Now it will be easier to mess with. When the car is running with the e-brake on and the car in park, when the switch is operated, you can hear the clicking of the interlock. But if it's not happy, it will get hot, so don't mess with it too much. 4) Get a new switch, and install it. If you are stuck at home with no car and are technically minded and the brave type, you can take this switch apart and repair it for short term use, or just blast the heck out of it with some lithium grease. Try just the grease first because the switch is evil to take apart and repair... I DO NOT recommend trying to fix the switch. I did, but you might not be able to and will now have a car which cannot move out of park until you get a new switch and you will curse my name every minute you spend wallking to the dealership. 5) The brave person has ignored my warning and now has no idea what they have in front of them... so here goes. *The switch consists of a top and a bottom, two springs, three contacts, a square-ish sliding part and the plunger. *CAREFULLY pull the square slider off the plunger, yes, it ratchets, so don't break it. *Pull the contacts out of the bottom. The Contact which sits on the plunger, actually goes underneath them, so when you put this all back together, put in the big spring first, the small contact, and then the two big contacts. *Now, carefully slide the square-ish slider into the assembly so that it goes into the middle contact, these parts only goe in one way, so experiment with it, one is easy, the other isn't, just pay attention. *Put the top part of the switch back on, yes, the plunger is still on the counter. This is easier this way. *When it is all back together, push the plunger in a LITTLE BIT. *Plug it back in to the wire assembly BEFORE installing it to make sure that it works. 6) Now, with the brake pedal in the resting position (as in, not pushed to the floor) push the switch into place, you will hear it ratchet as the plunger goes in. Check to see if when you press the pedal you get lights. Adjust the plunger so that you do. 7) Drive to the dealer BEFORE you put the dash back together, buy new switch, replace it, drive home, drink beer, put dash back together. Taken from another site. Greg.
1/18/2015 8:27:37 PM • RTO Automatic... • Answered on Jan 18, 2015
2004 pontiac sunfire not shifting from first gear
Hello, sounds like this will not be a homeowner capable fix as there are several possible reasons the trans is not shifting from first to second gear. In that transmission, Mechanically, 2nd gear is an intermediate band operated by a servo which pressures are controlled by shift solenoids. So basic daignosis would be to see if the solenoids are active before pulling the trans to take it apart for inspection of some key internal components like the condition of the band and the drum it holds as well as proper clutch engagement in the packs. Like I said, this is not not a do it at home job without GM automatic transmission experience. But before a teardown a bi-directional scan tool and a stethescope should be used to see if solenoids are at least active with the key on and a scan tool commanding the solenoids and listening to the case near the valve body to see if solenoid clicks can be heard before tearing into the unit. And another diag before teardown would be to drive the vehicle with the scan tool in transmission solenoid parameters visible to see if the PCM is commanding the solenoids to change and shift. Like I said, not a low tech diag. I was a Master GM tech and Shop Foreman for over 30 years building transmissions.
12/26/2014 3:31:05 PM • RTO Automatic... • Answered on Dec 26, 2014
Old/worn out automatic transmission in a 1995 checrolet cavalier
I suggest you get a rebuilt as it would be highly unlikely there would be a new one available. Check the auto transmission repairs in your area or Google the Internet for these repairers in your area.
12/17/2014 11:03:24 PM • RTO Automatic... • Answered on Dec 17, 2014
I changed my trany fluid and now it leaks out of the breather
-Possibly over fill. (more than enough). -Here how to check the automatic transmission fluid: 1.Make sure park your car on a flat (level ) surface .Start the car and let it idle for 10 to 15 minutes or until it reach normal temperature then check the fluid while the engine is still running. Good Luck Mai
11/15/2014 2:48:12 PM • RTO Automatic... • Answered on Nov 15, 2014
How is speed sensor have effect to transmission gear slip or free gear at high speed?
To perform optimally everything is controlled by a computer. If the computer gets a signal from the speed sensor saying your doing 30 and your really doing 80, the computer will adjust to perform optimally at 30 because that's all it knows. If the whole puzzle doesn't make sense to the computer it can do odd things such as not know what gear it should be in and find something inbetween.
11/12/2014 11:10:10 AM • RTO Automatic... • Answered on Nov 12, 2014
Ford autotransission will not go into any gear. put in a used tranny and it ran fine for 2 wks now i have no gears
-First check transmission fluid. If none or it's low , top it to full indicator and try to drive. -When check the fluid, engine must running and hot or normal temperature.. If fluid is full then next you need to check the shift cable to the control arm. Is it moving when you shift to D and other position...? If No. then possibly the cable to the arm is lose. If yes it move as you shift, then it's time for new transmission. Good Luck. Mai
11/10/2014 8:25:09 PM • RTO Automatic... • Answered on Nov 10, 2014
2answers
My 2000 Chevy Blazer is Pulsating ,jumping,jerking & going dead at red lights and such.Just had a rebuilt Tranny installed 13 months ago and then in July 2014 had to take it back and they rebu
A lot of info above, :) Me They cleaned the Torque Converter lockup switch and reused it seems to me, Have it rebuilt again and have the old part in hand this time, Symptoms of Lockup Torque Converter Going Bad eHow
11/3/2014 2:03:26 AM • RTO Automatic... • Answered on Nov 03, 2014
Bad transmission silinoid
You could have Explained What the car was doing BUT you most likely need a transmission Rebuilt since most Transmission lockup solenoid's can't be accessed to easy, BUT I'll Assume and say your having Shifting problems slow take offs most likely seems to be taking off in 2nd gear or seems stuck in 2 gears at once after warm,, Not to mention may be dying out at stop lights?.. But feel free to add more Info, :)
11/2/2014 6:02:03 PM • RTO Automatic... • Answered on Nov 02, 2014
When transmission fluid smells burnt, Does that mean that the transmission is already bad?
No, it means that a significant amount of the transmission fluid is "missing-in-action", and the heat generated inside the transmission is not being dissipated by the cooling effect of the fluid. Top-up the fluid.
10/31/2014 2:32:47 AM • RTO Automatic... • Answered on Oct 31, 2014
What tranny does my 1986 ford bronco 5.0 have?
Why dont you share with us if its manual or automatic please? Thanks.
10/28/2014 1:32:57 PM • RTO Automatic... • Answered on Oct 28, 2014
2answers
98 dodge ram 1500 re46 trans takes long time to
before replacing govenor parts try change fluid and filter its cheaper
10/17/2014 8:17:26 PM • RTO Automatic... • Answered on Oct 17, 2014
My 1999 dodge 1500 truck 5.9 engine is stuck in 3rd or4thgear on my automatic transmission. what do I do????
Your transmission is probably in limp mode. my 1998 had the same problem. I replaced my solenoids & governor pressure sensor to fix my truck
10/11/2014 10:50:22 PM • RTO Automatic... • Answered on Oct 11, 2014
Why is my transmission not putting out any movement when in reverse even though i can feel it selected?
think no reverse clutch. You need to have your transmission rebuilt.
9/25/2014 6:43:31 PM • RTO Automatic... • Answered on Sep 25, 2014
RTO Automatic Transmission And Engine Oil Pressure Tester Logo
193 questions posted
Top RTO Measuring Tools & Sensors Experts
Arleth White
Level 1 Expert
Are you a RTO Measuring Tool and Sensor Expert? Answer questions, earn points and help others
View Most Popular
  • RTO Measuring Tools & Sensors
Most Popular Question
code p0725 mean
  • Measuring Tools & Sensors
