SOURCE: i dont understand what it means by...
I beleive what they are asking you to do is to bring up the bobbin thread to the top of the throat plate( which cover the bobbin area, to do this you hold the top thread end and manually turn the wheel to engage the bobbin thread and bring it to the top of the throatplate, now you should be ready to sew
Maryann Sosewhappy
SOURCE: Can't figure out how to thread the needle
Here is the manual.
http://www.euro-pro.com/europro/manuals/8260.pdf
Good Luck and please Rate FixYa!
SOURCE: needle will not pick up the bobbin thread, gets
Oh boy! I've worked on industrial sewing machines for over 30 years, but the home sewing machines are like comparing cadillacs to mopeds. No offense, but if you want performance out of a machine try an industrial. It will shock you with the difference. Be glad to help you find the right one.
Anyway, the problem you are having is quite common. First, make sure it is threaded right especially the moving spring on the needle thread tension) and the needle is new. This generally covers 75% of the problem. Make sure the bobbin thread is threaded correctly.
If you are still having the problem remove the bobbin/bobbin case and observe the needle/hook point relationship as you turn the handwheel. The hook point should pass behind the needle at the scarf of the needle (indention just above eye of needle) If it is not so the needle bar may have moved up on you. Did the machine get jammed?
I'm not sure about the rod you're talking about but lets try this first.
