20 Most Recent Euro-Pro Shark 60 - 384 Questions & Answers
2answers
What size needle does the
The needle size depends on the type of fabric you're using. Generally, if you're sewing heavy or sturdy fabrics you'll need a size 16 needle. If you're sewing light weight fabrics, you'll need an 11. Nowadays, most machines will take any brand of needles. I hope this helps. If it does, please return and rate my suggestion.
10/18/2020 8:20:06 PM • Euro-Pro Shark... • Answered on Oct 18, 2020
I need replacement parts for a euro-pro sewing machine, model 384. I have searched & searched. HELP!!!!
-Try reliable part web site. Good luck Mai
1/11/2018 8:42:49 PM • Euro-Pro Shark... • Answered on Jan 11, 2018
Euro-Pro Shark Model 384 - Bobbin winding spindle won't rotate
-Don't know exactly it looks like, but make sure you press the bobbin either back or forward to engage the spindle to be able to spin the bobbin. Good luck Mai
1/11/2018 7:43:18 PM • Euro-Pro Shark... • Answered on Jan 11, 2018
User manual for shark euro pro model 384
Hello, this is Ava with Think Crucial. You may find the User's Manual for your Shark model by clicking the link below. Shark Euro Pro 384 Instruction Manual You can purchase a wide variety of high quality Shark replacement parts for your Shark vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10 https://www.thinkcrucial.com/collections/vendors?q=Shark I hope this was helpful. Ava B. Think Crucial Customer Care http://www.thinkcrucial.com/
11/5/2017 6:34:10 PM • Euro-Pro Shark... • Answered on Nov 05, 2017
How to adjust tension on Euro Pro X
You adjust the top tension according to what material you are sewing. More info needed. :)
11/3/2017 5:49:02 AM • Euro-Pro Shark... • Answered on Nov 03, 2017
I can't get the bobbin thread to come up
manualsonline.com
11/3/2017 5:48:20 AM • Euro-Pro Shark... • Answered on Nov 03, 2017
3answers
I need to know how to adjust the bobbin tension on
There is a tiny screw on the side of the bobbin case.
Mark the **** (in the screw head) position on the bobbin case with tiny dab of nail polish so you will know where the original setting was.
Left/loose and right/tight.
If you are adjusting because the bottom stitching is loose/loopy, first try threading the machine with the presser foot up to see if this solves the problem.
4/2/2017 7:10:03 PM • Euro-Pro Shark... • Answered on Apr 02, 2017
2answers
My sewing machine is stuck
hi,
1)Check if your machine is set to sew forward.If the spring doesn't appear to be stretched,drop of WD-40 sewing machine oil.
2)The reverse button is attached to the link that moves a lever to make the machine sew in reverse. The lever is spring loaded so it returns to forward sewing when the button is released. Either the spring has come off or there is a bind in the lever(oil it).
3)Some times pieces of thread or cloth gets blocked in it.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
3/2/2017 5:37:31 AM • Euro-Pro Shark... • Answered on Mar 02, 2017
How do I thread the Needle?
It is so difficukt to tell without pictures but I'll try. From reel of thread to loop or clip at left top of machine, through the thread guide, down the right side of the take up lever up over the left side, down the front through the loop and into to the needle loop then into the eye of the nedele. I sure hope this helps. :-)
6/3/2015 5:56:31 AM • Euro-Pro Shark... • Answered on Jun 03, 2015
Show do I thread the euro shark 60?
I believe it's on the right side back edge of your machine facing you, most machines have arrows printed on the machine for the direction the thread is to be threaded.
2/15/2015 9:52:17 PM • Euro-Pro Shark... • Answered on Feb 15, 2015
How to make a buttonhole
You shopuld have a button hole attachment foot and the instructions are in the manual. Try manuals on line.
2/2/2015 11:16:31 PM • Euro-Pro Shark... • Answered on Feb 02, 2015
What do I set for straight stitch on the shark euro-pro 384
It should automatically be set on straight stitch when it is switched on. Which means the needle is in the centre. (Hope this wasn't the reason you were given it.) You can try Manuals on line as Euro Pro is hard to get hold of.
2/2/2015 11:15:19 PM • Euro-Pro Shark... • Answered on Feb 02, 2015
2answers
How do I adjust the
Make sure that your top threading is right. My sister in law has this same machine and it is a really hard thing to do, Your manual has very vague instructions but check your thread going through the tension discs by pulling on the top thread with the presser foot up, it should pull smoothly, now put the presser foot down, it should barely move. /Sometimes this seats the thread in the tension discs. She is having no luck with the buttonhole making. In 50 years of sewing I have never seen a more vague manual and no customer service at all.
6/14/2014 5:51:38 PM • Euro-Pro Shark... • Answered on Jun 14, 2014
The know on the side of the machine that rotates the needle when turned by hand is tight, hard to turn. What do I need to do to fix it or adjust it so that it turns without having to force it to turn
I do have a couple of suggestions but would feel better if you'd first e-search Sharpe's site for your model's "Service manual"-a manual for simple repairs and how your machine disassembles and runs. With it you'd be a step ahead on a lot of your machine's maintenance and trouble issues!Don't give up too easily on your search.Sharpe likely sold the right to make your exact machine to other machine makers. These companies may have a Service Manual if Sharpe doesn't. You may be able to save and print from a PDF file. I'm not "up" on the newer machines so am assuming you have a belt drive machine: a rubber-like belt that is turned by the hand knob as well as the motor.What your describing is likely a too tight screw that secures the knob to the belt revolutions' workings (especially if the knob has been removed before). If your Sharpe knob pulls (toward your hand) to stop the needle for bobbin winding and THAT's too tight, then you have another screw in the knob to slightly loosen! In both cases, carefully disassemble the knob and look for the problem screw(s). Should the machine smell like burning rubber or make a screeching sound at high speed you'll need to change the belt and adjust it-probably with a professional.Old belts do get stiff, cracked and sometimes ragged so a new belt can make the motor run quieter and smoother.Hope this helps you especially, maybe others as well.
6/13/2014 12:23:26 AM • Euro-Pro Shark... • Answered on Jun 13, 2014
Bobbin assembly
It probably goes together much like this: http://www.manualslib.com/manual/85659/Kenmore-385-15208.html?page=68
5/25/2014 9:00:34 PM • Euro-Pro Shark... • Answered on May 25, 2014
I have been sewing all morning. Suddenly the fabric does not feed everything is clean
Look at the feed dogs to see if they are rising above the needle plate at least 1 mm. If not rising lint may have felted between the feed dogs and the needle plate. It could also be the feed dogs have been lowered, or the height has slipped. If the feed dogs are above the needle plate turn the hand wheel and see if they are moving from the front of the machine to the back. If not it is a length adjustment. If this is normal the pressure on the fabric may be too low. Another problem may be the timing of the feed dogs. The feed dogs should rise above the needle plate when the needle leaves the fabric and descend when the needle comes down into the fabric. This requires an expert to fix.
5/3/2014 2:21:00 PM • Euro-Pro Shark... • Answered on May 03, 2014
166 questions posted
Top Euro-Pro Sewing Machines Experts
Mike Cairns
Mike Cairns
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Euro-Pro Sewing Machines
Most Popular Question
shark 60 needle doesnt go up down
  • Sewing Machines
