20 Most Recent Euro-Pro 9105 Computerized Sewing Machine Questions & Answers
needle hook timing is set when the needle in the full down position has the bobbing carrier hook approaching the needle
AS the needle starts to rise the hook is at or just about at the eye of the needle
The adjustment is on the needle cam lever at the end of the machine and on most , there is a clamp around the shaft that is loosened of , the clamp tapped up or down to achieve the correct setting and re-clamped
Euro-Pro 9105... | Answered on Feb 16, 2018
Hi could you explain, what you mean by the machine jams up.\
Best wishes
Euro-Pro 9105... | Answered on Nov 02, 2015
Need more info.
Euro-Pro 9105... | Answered on Jun 03, 2015
Enter your model number here - http://www.euro-pro.com/europro/default.aspx for a download
Euro-Pro 9105... | Answered on Aug 28, 2014
Has the clutch been disengaged to wind the bobbin? Pulling straight out on the handwheel on some machines will stop the needle from moving so that a bobbin can be attached and wound. If this is the case you simply push it straight back in. Also, on a computerized or electronic machine if the bobbin winding post is pushed right, the clutch will disengage. --Push it all the way left when you are done winding the bobbin to re-engage the clutch. If the problem is internal, like a slipped belt, you will need to have someone open up the machine to repair it. Hope you get it going again!
Euro-Pro 9105... | Answered on May 08, 2014
New needle, right way around, and thread again from scratch, manual in hand. Make sure you're threading with the presser foot up. Raise the bobbin thread. Start each and every seam thus:
1. Place the work under the needle. Use the handwheel or needle up/down function to drop the needle into the fabric.
2. Drop the presser foot.
3. Hold the bobbin and top thread ends together and take about 3 stitches.
4. Drop the thread ends and sew normally. See also: http://www.picturetrail.com/sfx/album/view/22521551 last pair of photos.
Euro-Pro 9105... | Answered on Apr 29, 2014
Sounds like you need to loosen the tension.
Euro-Pro 9105... | Answered on Jan 20, 2014
Hi!
There may be so many reasons due to which the needle does not pick up the bobbing thread like---
The upper thread could be tangled. Remove the thread commpletely from the machine. The correct size spool cap should be used for the size of the thread spool. Re-thread the machine. Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race. Remove any loose threads or lint in the shuttle race. You could be holding the needle thread too tight. Hold the thread lightly to keep the end from going down into the shuttle. The needle could be thread incorrectly. Thread the needle eye from the front to the back. The needle could be bent or improperly inserted. Install a new needle with the flat side of the needle facing the back.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Euro-Pro 9105... | Answered on Jan 09, 2014
try oiling the machine
Euro-Pro 9105... | Answered on Aug 03, 2013
Euro-Pro 9105 Computerized Sewing Machine Logo
79 questions posted
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
View Most Popular
  • Euro-Pro Sewing Machines
Most Popular Question
presser foot not lower
  • Sewing Machines
