My copier is playing an April Fool's joke this morning. I loaded a one-page document in the top feeder to make multiple copies. Hit the start button. It started to tilt like usual to feed the paper down to the glass, wheels rolling just fine, then stops, beeps and says, "Re-load Original." I tried that, same thing. I turned it off and on, same thing. I looked for a staple, a paper clip, a stray piece of paper maybe stuck inside there, but nothing. I blew my can o'air into it, got some dust out, but it still goofs up. I can line originals up on the glass and copy that way, but man, that just takes so much time! Can you help me? Thank you!
Seems the wheels on the left side of the feeder maybe slipped or something, I turned them 1/2 way over so the gray rubber part shows, then they were able to grip the paper and feed it into the copier. That worked for a little while, then it did it again, I turned them again and it worked. Maybe I just need to make sure they have a little traction to solve the problem. Thanks for your website.
To "Settings/Registration Table"
You can specify the method for restarting scanning of documents when a paper jam occurs in the feeder.
For information on the optional products required to use this function, see "Optional Products Required for Each Function."
Details of each item are shown below.
[From 1st Page]:
If a paper jam occurs in the feeder, scanning starts again from the first page of the document.
[From Stopped Original]:
If a paper jam occurs in the feeder, scanning starts again from the page of the document scanning was interrupted.
