Canon PIXMA iP1500 InkJet Photo Printer Logo
Posted on Mar 31, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Flashing 3 times orange then green?
Hi, my printer flashes 3 x orange, then 1 x green and won't print or switch off? HELP?!
Starnley Johnwells
Level 3:
  • Master 1,031 Answers
  • Posted on Mar 31, 2009
Starnley Johnwells
Master
Level 3:
Answers
1031
Questions
Helped
607771
Points
3590
4 step to Reset waste counter CANON PIXMA iP 1500
STEP 1:- Disconnect printer from AC power(unplug it from all source of power supply leave it for 5min then back after))
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
1helpful
2answers
Green light flashes, will not print. Checked all
Hi can gave you the truble codes
  • Light Orange - 2 beeps: Remove any paper jammed
  • Light Orange - 3 beeps: Remove any paper jammed
  • Light Orange - 4 beeps: Add Ink
  • Light Orange - 5 beeps: Re-install cartridge or replace it
  • Light Orange - 6 beeps: Re-install cartridge or replace it
  • Light Orange - 7 beeps: Re-install cartridge or replace it
  • Light Orange - 8 beeps: Waste is almost full
  • Flash 1 x Orange - 10 beeps (error code 6100): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 2 x Orange - 10 beeps (error code 6300): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 3 x Orange - 10 beeps (error code 6800): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 4 x Orange - 10 beeps (error code 5100): Make sure nothing is blocking the cartridge movement, if not requires service.
  • Flash 5 x Orange - 10 beeps (error code 5400): Try unplugging the printer for 30 seconds, if not requires service.
  • Flash 6 x Orange - 10 beeps (error code 5B00): Waste full (make a reset)
  • Flash 7 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 8 x Orange - 10 beeps (error code 5200): Replace the BJ Cartridge(Printhead)
  • Flash 9 x Orange - 10 beeps (error code 5600): Replace the BJ Cartridge(Printhead) or reinstall it
  • 0helpful
    Light flashing green and yellow will not print
    Hi this is only a try it may work
    Start with the printer OFF
    1. Hold down RESUME and then hold down POWER
    2. Release RESUME
    3. Press RESUME twice, then release POWER
    4. Let green light blink until printer is done futzing
    Select function with RESUME press POWER to execute:
    presses - light color - function
    Number of presses - light color - function
    0 presses - green - Test print (or exit service mode on i960)
    1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i960)
    2 presses - green - EEPROM initialize
    3 presses - orange - Reset waste ink counter
    1helpful
    2answers
    The printer flashes orange light five times, and green once
    Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
    1. Start with printer OFF
    2. Hold down RESUME and then hold down POWER
    3. Release RESUME
    4. press RESUME twice, then release POWER
    5. let green light blink until printhead has finished moving.
    6. Select functions below with RESUME, execute with POWER
    0 presses - green light - Test Print (exit service for i960)
    1 press - orange light - EEPROM info print
    2 presses - green light - EEPROM initialise
    3 presses - orange light - reset waste ink counter.
    This also applies to the i550, i560, i950, i960
    2answers
    6 orange and 1 green flashing light on S400 canon bubblejet
    Friend your printer has reached to its printing limit. Its printer has a maximum of printing point it is registered in the printer memory. When it reach to its limit it will stop. To solve this problem you need to use CSS Utility Software so that you can make the printer reset then you can print again. You can download for just type CSSutility software in google or yahoo. then download.
    Operator Error Canon i850 printer
    2. Release RESUME
    1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i850)
    1helpful
    BJC55 Printer not printing
    There are some possibilities due to the above phenomena. Let's discuss about it:
    1) If the POWER light is flashing green, then your printer is now warming up or performing maintenance procedure (replacing cartridge/tank) or cleaning print head, just wait a few seconds till the light stop flash. Also if the last page of a print job not done, this POWER light flashing green.
    2) If the CHARGE/ERROR light is flashing orange with beep 3 times, it mean your cartridge need to be install (especially the 1st time turn on printer) or cartridge being replaced, just install the cartridge and press RESUME to continue.
    3) If both POWER light is flashing green and CHARGE/ERROR light is flashing orange with beep 3 times, then your printer may facing a very serious error and maybe need a replacement.
    Hope these help.
    YBC (/\)
    1helpful
    Canon i950 will not reset counter for waste tank full.....
    For Canon i850, i950, S600
    2. release RESUME
    3. press RESUME twice, then release POWER
    Canon BJC 8500 WASTE INK FULL
    How to Reset Waste Ink Protection Counter Canon Pixma IP8500 Printer
    Instructions:
    Resetting Waste Ink Counter Canon Pixma IP6000, Canon MP450, Canon Pixma IP8500
    1. Turn off the printer.
    2. Whilst pressing Resume button also press on POWER.
    3. Then Press RESUME button and release POWER.
    4. Then Press RESUME button again .
    5. Then release all buttons.
    6. Led Indicator should be green and stay green.
    7. Click RESUME button 4 times if you wish to try again.
    Then See Table Below:
    Orange - Service test print ONCE - Orange - Service test print.
    Green - EEPROM information TWICE - Green - EEPROM information print.
    Orange - EEPROM initialization 3 TIMES - Orange - EEPROM initialization.
    Green - Waste ink counter resetting 4 TIMES - Green - Waste ink counter resetting
    Orange - Destination setting (Press Power then Press Resume 3x) 5 times - Orange - Destination setting (Press Power Press Resume 3x)
    Green - Print head deep cleaning 6 TIMES - Green - Print head deep cleaning.
    Orange - Green, Orange - Return to menu selection 11-13 TIMES - Orange, Green, Orange - Return to menu selection.
    Green - Left margin correction 14 TIMES - Green - Left margin correction.
    8. Turn off printer.
    9. Restart Printer.
    Good Luck!
    Tinteiros - Magic Inkjet Flush (Ebay)
    old marine
    old marine
    ZJ Limited
    ZJ Limited
