I have a HPDeskjet 2360D Printer installed on my regular computer. I have purchased a wireless Laptop with a router and need to download installation and instructions to tie the laptop to the printer. Can you please help me.
Connect your 123.hp.com/envy5660 printer after the printer hardware setup before you print or scan from a computer through a wireless network. Install the HP printer software from a wireless network from a computer with Windows 7 or later. STEP 1 : BEFORE INSTALLATION
If you want to connect the printer 123 HP Envy 5660 Setup to your wireless network, make sure you know the network name and password.
Connect your Windows computer to the wireless network and make sure the HP printer is compatible with the wireless
Obtain the network name (SSID) and network passphrase (WEP key or WPA). A broadband internet access is must be used. Make sure you have the USB cable provided along with the printer package.
Turn on your printer, router, and computer and make sure the computer is connected to the same wireless network you want the printer to connect to.
If you have connected any USB cable to the printer, disconnect it before you proceed with the software installation.
Follow the instructions to remove the USB installation if it was previously setup on your computer before you continue:
Search for the HP folder in the list of installed software programs, click the HP printer folder, and then click 123.hp.com/envy5660
Once the HP Printer Assistant software opens, click Utilities -> 123.hp.com/setup 5660 & Software Selection.
Continue to follow the prompts and click Convert a USB connected printer to wireless or Connect a new printer.
To complete the software installation, follow the on-screen instructions.
You can also run HP Print and Scan Doctor, an automated tool to connect the printer to your wireless network.
STEP 2 : CONNECT TO THE WIRELESS NETWORK
Connect your 123.hp.com/envy5660 printer to the wireless network using the built-in Wireless Setup Wizard to identify network name and entering the network password.
If the printer is not turned on, press the Power button to turn it on.
On printer's control panel, touch the Wireless icon to preview the Wireless Summary screen.
On the Wireless Summary screen, touch the Settings icon and then touch Wireless Settings.
Under the Wireless Settings menu from 123.hp.com/setup 5660, select Wireless Setup Wizard and follow the on-screen instructions to complete the setup.
STEP 3: DOWNLOAD AND INSTALL HP PRINTER SOFTWARE
Download the supportive 123.hp.com/envy5660 printer software from our website once the printer is connected to your wireless network.
Turn on your HP printer and eject any USB cable if connected to the printer.
Go to our website and navigate to the download page where you have to download the printer software manually.
Select your printer model when prompted and then, follow the on-screen instructions to reach the download page.
Next, to the full feature, click Download or click Basic Drivers.
If you don't have the original installation disc, look at the brand and version of your printer. Go to the main website for the manufacturer and search for the version of your printer. There should be a download available. Download this to your laptop. Use a USB cable or the cable that comes with the printer and plug it into your computer and the back of the printer. After you've done this, run the installation software on your laptop and follow the instructions. Unplug when the installation is complete, or if you have wifi and the printer is compatible, follow the instructions to also connect it for wireless printing.
You'll need to install the printer driver on your computer. From there, the Lexmark software will give you step-by-step instructions on how to install and setup your printer.
Please visit the Lexmark website to download and install the
Lexmark X4690 Printer Driver on your computer. Select your operating system
> click on "FILTER" > click on the driver under Recommended
Downloads > download and execute the file. Simply follow the instructions on
your computer screen to complete the installation.
After installing the printer driver, try to print a document to verify that the software is installed successfully.
Yes you need to setup the printer as a shared printer using the printer driver CD. Your shared printer and computer would need to be on your LAN and connected to a wireless router. The laptop will connect to the shares printer via the wireless router and LAN cable to the computer with the shared printer. Please click on this link and follow my instructions to setup the shared printer. http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
unplug the usb cable... have the printer disconnected from the computer...open the printers and faxes under control panel in ur computer.... delete all the icons related to ur printer... once that is done, insert the installation cd which u got while u purchased the printer.... go on with the on screen instructions and keep clicking on next.... and while u install the software, the installation screen itself will ask u to connect the printer... at that time plug in the usb cable and make sure that the printer is turned on... and again go on with the on screen instructions until u hit finish... thats it!!!
Normal
0
If you printer does not have a built-in network card then for the laptop and computer to print via wireless to this printer either then, the printer needs to be connected to a print server or setup as a shared printer. A shared printer is the cheapest and easiest option. Please click on this link and follow my instructions to setup a shared printer :- http://www.fixya.com/support/r3668797-setting_up_shared_network_printer
Yes, the printer can still be connected to your computer via the USB cable. Before connecting the printer to your computer, I suggest you insert the installation cd in your computer first. Run the software and follow the instructions on it. While it is installing, the software will also show you a step-by-step instructions on how to setup the printer itself. Hope this helps.
download your driver for printer then install. Your drivers installation is corrupt so download new installation from above link. Let me know if you need more assistanse. Thanks.
where can i download free installer/driver for my hp d2360
