20 Most Recent HP Deskjet 2360 InkJet Printer Questions & Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Please leave Comment or Rate answer for me to improve in the future
HP Deskjet 2360... | Answered on Feb 22, 2019
Logon to www.hp.com/uk
select support and enter the Deskjet model number.
run diagnostics
wait for report
follow instructions
hopeful that will fix it.
HP Deskjet 2360... | Answered on Jan 19, 2018
hi
you can get it from
Software & Driver downloads HP Deskjet D2360 Printer
select your o/s to download.
riz.
HP Deskjet 2360... | Answered on Jan 04, 2018
Hello there
You may not see a paper jam.
This may work for you, it has worked for many here I given this advice so gave it a try it could work for you. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
HP Deskjet 2360... | Answered on May 31, 2017
You can download the drivers and softwre for your printer from the HP product support pages
Just click here
Download drivers and software Download drivers and software
HP Deskjet 2360... | Answered on Sep 05, 2016
your printer correctly installed to your pc the printer driver I mean did your install it correctly? The usb cables has correctly attach to the CPU and printer? Thier is no broken wires of your usb cable did you try to replaced it with new one usb cable.
HP Deskjet 2360... | Answered on Aug 08, 2013
Dear user,
Your printer already have many commands given for print. that why is prints all that data which is already have given.
To clean the print commands. open your printer from Control panel---> printer and faxes--->> your printer
and then cancel all the commands which are waiting to be print.
You will not have anymore unwanted prints.
Note:- Please dont forget to RATE my answer
HP Deskjet 2360... | Answered on Jul 09, 2012
Hello
This light blinking will take place when there is a bad cartridge or some mechanical obstructions in the carriage path. try to replace the cartridge first.
HP Deskjet 2360... | Answered on Jul 24, 2011
These problem is actually occare during printer cartrige failior. I think you should need to replace your printer cartrige with new one or two.
Thank you
Are you using refilled cartridges,
HP Deskjet 2360... | Answered on Jul 06, 2011
HP Deskjet 2360 InkJet Printer Logo
129 questions posted
Clive
Clive
Ekse
Thomas F. Schneider
View Most Popular
DeskJet HP
  • DeskJet HP
Most Popular Question
hp 2360 inkjet printer driver
  • Office Equipment & Supplies
