Canon powershot A460 camera is not recognized by my computers. worked fine for months. reinstalled software several times. same results.
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: I have a Canon Powershot
If this camera is under warranty you should carry it to the Canon Care Center they will replace the Zoom lens unit of your camera, or you need to get it replaced on payable basis as the lens has some strucking problem.
Regards,
Manoj Joseph
+91 9352008418
SOURCE: Canon PowerShot A590 camera won't turn on. I have
If you make sure that the memory card is properly seated and the batteries in and the battery door properly closed, then it should power up. If still no success, it may be the micro switch that closes when the battery door is closed.
SOURCE: Computer Not Recognizing Canon PowerShot SD1100 IS Elph A
Depending on your OS, you can download the latest driver for your system directly from Canon here. Remember to select your OS in the dropdown tab to be able to see the available downloads.
But I'd also recommend that you take this as an opportunity to consider utilizing a much safer method of downloading your pictures and videos. Please see this link, as it describes the use of a USB card reader as a much easier, faster, and less error prone way to download your photos. Note that card readers are also VERY inexpensive these days (some places less than $2 online with shipping).
SOURCE: I need driver software for Canon PowerShot A460
go to link below and get your software. Canon PowerShot A460 http://software.canon-europe.com/products/0010422.asp
SOURCE: All the pictures taken outside or in lighted area
Go into the menu and find "reset"...follow the on-screen instructions.
Sometimes a simple update on the computer will ruin an otherwise perfect setup. Direct from camera to computer downloading is fraught with bugs. Have you tried using a card reader? They almost always solve the problem and work fast too. Only $10-20. Also get free software Picasa3 from Google. It downloads and organizes your images great plus lots of other goodies. You'll love it.
