Did you replace the inverter board?? It is inside the tan plastic box in the bottom of the control panel I think on the right side. That controls the power supply to a good part of the machine and drive system. Has to be a direct short somewhere to trip the breaker.
bad multiport gasket you can get along by putting a ball valve on waste line or a plug in the pipe until you get another multiport gasket if you replace talk to who you buy it from some need to be cemented into place
If this problem happened after you replaced the filters, check that the filters have been installed correctly because some filters have sensor magnets installed on them and unless they are in their correct position, the machine wont power on.
Hi, you need to clean out your outlet filter; this needs to be done
periodically - according to your usage. If this does not solve your
problem check out your outlet pump. Plug off the wall first before you
do the jobs. The machine will not drain water if the outlet is clogged.
You need a filter on every outlet where a phone is hooked. If no phone is plugged no filter is needed. A filter by any name is still a filter. No need to have the same make.
Is there suction where the pipe hooks to the cannister? If so, then are all of the outlets without suction? Maybe the hose is plugged. If the hose is ok, and there is suction at the cannister, then **** up a small **** of paper, one for each room outlet, have a number on each piece of paper, Which ever one doesn't ,ake it thru to the cannasiter is the outlet that is plugged. You can use a plumbers snake to clean out a clogged outlet or even a clogged hose.
If the motors are running and sound ok, then there has to be suction at the outlet on the cannister. If the filter bag is old, it may be best to replace it with a new one.
Possible your outlet filter is blocked. This requires cleaning depending on your usage. Plug off the wall, refer to manual re. outlet filter. Siphon out maximum water by removing the tube from behind machine which goes into wall drain. (refit this after cleaning into EXACT position) Clean outlet filter and refit. Good luck.
When your outlet filter is clogged or blocked, the machine refuses to spin.
Try the "spin only" button to take the water out of your machine. If this does not work, take the pipe from the wall socket and lay it on the floor for the water to spill out. The spin normally does not work when the outlet filter is clogged; if the filter is clean you should then check your pipe coming out from under the tub (plug off the wall first before doing all these things). Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes. Plug off the wall, & check your outlet filter first.
You need to clean out your outlet filter; this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain if the outlet is clogged.
