Kohler Toilet - One Piece with Ingenium Flushing System - San Raphael by Logo
Anonymous Posted on Feb 16, 2013
Water is not coming out on the top of the fill tube that connects to the overflow tube
This is a a new fill valve. Water fills up the tank and stops at the right level. However, while the tank is filling up, I don't see any water coming out the small plastic tube at the top that connects the fill tube to the overflow tube. The fill valve is the blue float with white plastic tubing. Kohler 1068030
Bill Dickerson
Level 3:
  • Master 979 Answers
  • Posted on Feb 16, 2013
Bill Dickerson
Master
Level 3:
Answers
979
Questions
0
Helped
309528
Points
2196
It doesn't usually have water coming out. If it fills the tank, it is ok. The water is coming out at the bottom anyway. However, the adjustment on the tube is off and not allowing water in .
  • Anonymous Feb 16, 2013
    what adjustment do I need to make so that water flows into the overflow tube while the tank is filling up after a flush
1 Related Answer
BarrettDenCo
Barrett Palumbo
  • 1772 Answers
  • Posted on Jan 05, 2011
SOURCE: should water be coming out of the base of the
yes both, but you have a float adjustment issue
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Water keeps filling in toliet even after full
hi Patricia.
Overview Toilets haven't changed much in the last 80 years. After a flush, water still fills a tank, lifting a float that shuts off the water when it reaches a certain level. A lever still opens a flapper to cause the flush, falling back into place when the water level drops. So it's no surprise (nor any consolation) that we face the same flush problems today that our grandparents did. Sometimes the flush is too wimpy, sometimes the toilet keeps running, and sometimes the bowl doesn't refill.
Our ace plumbing consultant has a simple four-step strategy to solve 95 percent of these problems. You can complete the first three steps in five minutes. That'll solve most problems. The fourth step is usually easy too, but not always. More on this later. These steps work for most toilets but not for pressure-assist models.
Check the fill tube
Overflow tube problem
Push the fill tube firmly onto the fill valve. Make sure the fill tube sends water into the overflow tube.Remove the tank lid and find the fill tube. It's a small flexible tube that runs from the fill valve to the overflow tube. While the tank refills, this tube squirts enough water down the overflow tube to refill the bowl after the completed flush. If this tube falls off or the water stream misses the overflow tube, the bowl won't fill and your next flush will be wimpy (that is, won't develop a strong siphon). Reattach the fill tube and make sure it perches about 1 in. above the rim of the overflow tube. Flush the toilet and watch the water stream to make sure it goes down the overflow tube.
Adjust the fill height
Check the float
Adjust the float to set the water level. Pinch the clip and slide the float up or down on the rod. Keep adjusting the float until the water shuts off at the proper level.The water level in the tank is controlled by an adjustable float. A float that's set too low produces a weak flush; if it's set too high, water spills into the overflow tube and the fill valve won't shut off. The toilet keeps running. Look for the fill level mark on the inside back of the tank and mark it on the overflow tube so you can see it more easily. If you can't find it, measure down about 1 in. on the overflow tube and make a mark. Then flush the toilet and see if the water reaches and stops at that mark. If not and the toilet keeps running, adjust the float up or down. If you have an old toilet, you'll have to bend the brass rod that connects to the float ball to make adjustments. But with newer toilets you usually turn a screw or slide a clip along a rod. Flush the toilet after each adjustment.
Also make sure that the water level is at least an inch below the C-L (critical level) marked on the fill valve. You can adjust the height of many valves to raise or lower the C-L.
Occasionally the fill valve simply won't shut off, which means that it's defective. If so, turn the water supply off at the shutoff under the tank. Buy a replacement valve (sold at hardware stores and home centers). You don't have to match the old one; many, like the one shown, fit most toilets. It's a 15-minute change-out.
Adjust the flush handle/flapper chain
Flapper chain fix
Adjust the chain to leave a little slack with the flapper closed. Then cut off the excess, leaving about an inch.A chain that's too short or tangled won't allow the flapper to close and water will continue to leak into the bowl. This causes the fill valve to cycle on and off to refill the tank. A chain that's too long, or a flush rod that hits the the tank lid, won't open the flapper wide enough to stay open for the full flush. You'll find yourself having to hold the lever to complete a good flush.
To avoid these problems, adjust the linkage in the chain to leave only a slight bit of slack when closed. Cut the chain at the rod to leave only about an inch extra to reduce the potential for tangles. Then put the tank lid back on and make sure the flush rod doesn't strike the lid when you press the lever. If it does, bend it down slightly and readjust the chain.
Replace the flapper
Change the flapper
Unsnap the old flapper and take it with you to the store to find an exact replacement. In addition to the closest replacement, pick up a "universal" type.If you've completed the first three steps and your toilet keeps running, chances are you have a worn-out flapper. Turn off the water, remove the old flapper and take it to the store to find an exact replacement. (Hardware stores often carry a wide variety.) Most flappers snap over ears on the overflow tube. Others have a ring that slips over the tube.
Now here's the catch. You may not find an exact match. The range of flapper styles has mushroomed over the last 15 years, and you may find 15 to 20 flapper options on the store shelf. Some packages include specific brand and model information (so note yours before you leave home). Others have a "universal" label. If you can't find an exact replacement, try the closest one and pick up a universal type as well. They're cheap, and the extra one just might save you a second trip to the store! (Avoid the "adjustable" types unless you're replacing an adjustable one.)
Install the new flapper and make sure it opens and closes freely. Then test it. If the toilet keeps running or runs intermittently, you're not getting a good seal. Try a different flapper if the toilet won't stop running.
If you just can't find a flapper that seals, consider replacing the entire overflow tube/flapper. On most toilets (two-piece), this means removing the tank. It's not difficult and you don't need special tools. It'll take you about an hour, and you'll avoid that expensive plumber service call.
if you go to this link it will show you step by step on how to fix it. How to Stop Running Toilet Family Handyman
Nov 27, 2017 • Home
1helpful
After my toilet fill valve shuts off, water continues sipping into tank slowly. This causes water continuously overflow through overflow tube.
check that the fill valve was installed correctly
adjust the float level so that when full the cistern water level is around 1/2" below the over flow pipe end
what you have now is that the inlet water is not being shut off correctly and the water is still coming in and flowing out of the overflow
The fill valve will not shut off in the toilet tank. Water continues to run out of the overflow tube of the valve into the overflow tube of the toilet., even after the valve has been adjusted.
After flushing the toilet, water still fills the tank till then the shuts off valve reaches a certain level. When the shuts off valve reach the level it disconnect the water connection to the tank and the filling process of the tank shuts off.
So, if your fill valve didn't shut off then maybe there's a problem with the shuts off valve, open the fill valve and fix it. If you can't fix it call a plumber for it.
The toilet isnt flushing and water is not filling into the cistern? (at the top) how do i fix this problem??
If I understand correctly, the tank that holds water is not filling up with water.
1) If this is the problem, then you need new toilet fill valve.
Or clean sediment out of existing fill valve by removing and soaking in CLR calcium rust lime.
To replace fill valve:
Look at water supply line coming into tank.
Supply line connects to fill valve.
Buy new fill valve at home center, hardware store, or walmart, or online.
There are two nuts connected to valve. Each nut has companion rubber washer
One nut & washer seal water supply line to tank.
Second nut & washer seal valve to tank.
2) If water tank is full of water, but water does not flow rapidly into bowl when you push flush lever, then your toilet is clogged with sediment.
To solve sediment problem when flush water will not flow rapidly into tank, then buy CLR calcium lime rust.
Pour CLR down into overflow tube located inside water tank.
Make a funnel by cutting off bottom of water bottle, or cut paper cup into a funnel.
Pour cup-full after cup-full of CLR into overflow tube until sediment and CLR are coming out all flush holes located under-rim on bowl.
3) Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 22, 2011 • Home
Tiolet not flushing right. Water not coming down the side of the bowl when flushing and 90 percent of the water is gone from the bowl.
1- Check ports out under rim all round bowl.
2-Check tank fill level for required amount to with in 5/8" to top of over flow tube.
3-Make sure 1/4" fill tube is connected to over flow tube. From fill valve to overflow tube.
Below is a few details to go by I hope will be helpful for you to take care of this problem.
Under the rim of the bowl check the ports and make sure they are not stopped up. You can open them up with nail or pin to clean out ports.
Next check tank level and make sure the fill valve has a line run from it to top of the overflow tube. This line allows water to goe to bowl and tank to fill required amount needed.
Water in tank should be within 5/8" to top of over flow tube.
How to fix fill water shooting up and over when flushing?
I don't exactly know what you mean so i will cover all the basics. The fill valve sends fills water in 2 locations. 1) the fill valve fills at the low end (from the bottom to the top) of the tank. This is the flush water level. It needs to be stopped by a float switch before the water overflows into the over flow tube.
2) the fill valve fills water via a small tube at the top of it which this tube NEEDS to be pointed into the overflow tube with a high arch. THIS water is filling your toilet bowl section to proper flushing height. If your water in your bowl does not reach proper height and someone removes this tube to aim it into the tank where the other water is stored, THEN you may have the problems you described and you will need to do several flushes to remove waste.
SO to reiterate 1) make sure your float cuts off and stops the filling cycle before the water flows into the over flow tube. This is done from 1 or 2 adjustment screws. and 2) make sure the small black tube is aimed down into the over flow tube with a good arch. The arch prevents back siphon.
1helpful
Kohler Highline Class V tech toilet. Bowl does not fill. Why? What can I do to fix it?
Check tank for fill line running from fill valve to overflow tube. It will be a 1/4 " line that allows the tank and bowl to fill. It should be connected from fill valve and connected at the top of overflow by a clip or hanger.
Check out the water level in tank to make sure it is filling to line on overflow or within 5/8" to top of overflow pipe.
2helpful
2answers
Toilet tank looses water over time
As long as there is no water leaking from the tank to bowl connection, you are OK. You would know if it was leaking here, because you would have water dripping out onto the floor.
Verify that the water level in your tank is below the top of your new flush valve's overflow tube. If the water level comes to the top, it will overflow into the toilet bowl. This can be easily fixed with an adjustment to the fill valve.
If the water is not overflowing into this tube, then the only way you can lose water is through the flapper. You said you changed the flush valve, which would have come with a new flapper attached to it, but maybe buy a new flapper and see what happens???
5helpful
Toilet tank fill valve sprays water towards lid
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
Top Kohler Home Experts
john h
ZJ Limited
ZJ Limited
Are you a Kohler Home Expert? Answer questions, earn points and help others
