20 Most Recent
Kohler K-3360-G Revival One-Piece Toilet With 12" Rough-In, Seat, Cover, Br Questions & Answers
I have K3397 Kohler toilet.
open were the water system is flush once watch the water rise localize the floaty tat rises with the water once u localize the floaty their will be adjuster were the floaty is then just lower the floaty adjuster down 2 half inches down once ur dun flush then the problem shud be solved.
Our topflush toilet will nto stop running, once it
after flushing observe flapper if it flops back and water is still getting by when tank is full than replace the flapper /if water is running down tube [high level]in tank than adjust level or if not responding to adjustment than flush unit is bad
Toilet tank fill valve sprays water towards lid
Hi bpmorr1,
It may be that the fill tube has come disconnected . It runs from the top of the fill valve to the overflow. The overflow is the tube that runs up the middle of the tank. The fill tube runs from the top of the fill valve to the top of the overflow tube. Kohler has a little clip that can sometimes come undone and cause spraying.
If that doesn't do it, turn the water off to the toilet and take off the tank lid. Partially open valve ( Slowly). Locate where spray is coming from. If it is in the area on top of the fill valve then yes, buy anew one. ( Fluidmaster )
Please rate this response and good luck, Phil
Toilet seat covers protection
Nope, but your seat doesn't really need protecting. All those paper covers do is mentally separate your backside from the countless bums that have occupied the same space.
Need password for a stolen file
Okay. The question is a bit lacking in details. Password for what? Password ON what? Where was the file stolen from? Who stole the file? What is the file content. What is the file extension (the bit after the file name and the period file_name.what)?
All questions need to start 'make model (what it is)' first 3 words. And then a clear question.
For the 13 people that have tagged this 10 year old question, it is better to post your own question.
2/7/2024 6:03:08 AM •
Kohler Home
Answered
on Feb 07, 2024
