20 Most Recent Kohler - Toilet - Two-piece - Highline - K3427-RA-G9 Questions & Answers
I had cascade toilets with a pull handle. Once I unscrewed the handle, there was a nut that held the lid on. Remove that, then the lid, then you should be able to get to the mechanism.
Kohler - Toilet... | Answered on Jan 13, 2018
get a plumber in under warranty to fix
Kohler - Toilet... | Answered on Oct 16, 2016
flapper.jpgFlapper or flush valve needs servicing
First try cleaning minderal deposits from around the valve seat. This can keep the flapper valve from sealing properly and allow water to seap into the bowl. First turn of the water and flush the toilet to empty the bowl. You can unhook the flapper valve to get it out of the way. Using emery cloth scrub the inside of the valve seat to remove the mineral deposits. Next coat the valve seat with petroleum jelly to help the flapper valve make a tight seal. Replace the flapper valve, turn on the water and check to see if the water still leaks.
If the flapper valve is old it may be deformed. In this case you will need to replace it. You can unhook the valve and remove the lift chain from the valve. Be sure to purchase a similar size replacement valve.
If the valve seat is damaged you will need to replace the entire flush-valve assembly. You will need to remove the tank to do this. Be certain to turn off the water supply and flush the tank to drain it. You might also want to place newspaper and towels on the floor to soak up any water that may leak out. Using and adjustable wrench loosen the nuts at the supply tube and push the tube aside. Next, use a flat-head screwdriver to hold the bolts inside the tank still while using an adjustable wrench to loosen the nut on the bottom of the tank. You will then be able to lift the tank off of the bowl. Lay the tank on the newspapers or towels.
To replace the flush-valve assembly first remove the old one by unscrewing the locknut on the bottom of the tank. Use a hacksaw to cut the new overflow pipe to 1/2 ince below the tank top. Put plumber's putty on the washer at the base of the flush-valve assembly and push the assembly against the tank opening, removing any excess putty. Use a monkey wrench to tighten the locknut. Replace the gasket over the locknut and replace the tank on the bowl and reassemble them.
Kohler - Toilet... | Answered on Sep 14, 2015
check for correct water level in the cistern
have a plumber clean out the lines as there may be a blockage in the pipe
Kohler - Toilet... | Answered on Jun 08, 2015
There should be a small hose that is spraying the water. That hose should be put inside the overflow tube and heald in place with a clip or put into a small hole on top of the tube. Only put the tube in just enough to hold it in place. If it is spraying from anywhere else you need to replace or repair the ballcock.
Kohler - Toilet... | Answered on Nov 13, 2014
sounds like something is missing. There are various models in the highline series, which one is it?
Kohler - Toilet... | Answered on Oct 30, 2014
Yes it should be fine, go to Kohlers website and check the rough-in dimensions to see what size the waste hole is on the toilet usually 2 3/8 to 21/2. If it says 3 inch you might just need an adapter ring.
Kohler - Toilet... | Answered on Sep 20, 2014
If it is a float and rod type, there is a screw that will adjust water level but firmly grasping the rod with both hands and bending the float up or down as needed is still the old tried and true method. If it is the newer fluidmaster type there is a screw adjustment on the float.
Hope this helps.
Bob
Kohler - Toilet... | Answered on Aug 01, 2014
Fuse or the fan relay.....Undo the coolant temp sensor and see if it comes on, if it does then its the relay.....or wait until motor gets warm then check the plug to the fan (make sure you undo the harness 1st), is getting power....if it does then your fan is shot....
Kohler - Toilet... | Answered on May 09, 2012
Hello, W/D here.
Most probably, the tank-to-bowl gasket has not seated properly. They are usually neoprene, and tend to bight on the bowl socket rather than to slide into the socket where it can be compressed properly. Remove the tank bolts and look at the gasket. Re-install, using a water based lubricant on the bowl side, with the gasket installed on the tank flange. Wiggle the tank and gasket back and forth a few times, and the gasket will start properly into the cast socket on the bowl. Install the bolts and tighten to finger tight. Wiggle the tank a bit more, and level the top. Tighten the bolts uniformly.
You mention that the flush valve was hand tightened only. If this gasket is not snug (a bit more than hand tight), a leak can occur there as well.
Best regards, --W/D--
Kohler - Toilet... | Answered on Jan 21, 2012
at the hinge of the seat there are caps that should snap open. underneath there are two bolts simply unscrew then then replace the seat
Kohler - Toilet... | Answered on Nov 08, 2011
You need to change the valve. It probably is stopped up with calcuim, etc.
Kohler - Toilet... | Answered on May 18, 2011
quick solution is to read 500 times this quote.
peace be upon him.
patience.time heals this time is a great healer
till the problem will solve.
plz request fixya to not delete my account.
blockporn.tk
Kohler - Toilet... | Answered on May 15, 2011
You cannot adjust the pressure on the toilet. But you can adjust the stop setting screw at the top of the float arm. If the water is coming in too fast you can adjust the valve where the toilet water line connects to the wall water supply. Closing the valve a little will slow down the flow of water and it will take a little longer to refill the toilet water tank.
Kohler - Toilet... | Answered on Mar 06, 2011
This link will help you
http://kohler.dirxion.com/toiletserviceparts
The flapper is not proprietary to this unit an after market flapper will work as good and in most cases better. The flappers offered but Fluid Master are in my opinion the best out there. Remove the flapper and match it up with one offered but them, install it and you will be good to go.
The problem with getting the stock part is that the toilet your working on was discontinued so time ago and unless you are ready to give up your 3.5 gallon flush toilet keep fixing it as long as you can.
Kohler - Toilet... | Answered on Mar 05, 2011
Kohler - Toilet - Two-piece - Highline - K3427-RA-G9 Logo
56 questions posted
Top Kohler Home Experts
US Parts Center
US Parts Center
Donni Steen
john h
Are you a Kohler Home Expert? Answer questions, earn points and help others
View Most Popular
Kohler Home
  • Kohler Home
Most Popular Question
hard flush
  • Home
