Jackson 25 in. TempStar HH Free-standing Dishwasher Logo
A
Anonymous Posted on Feb 06, 2013
Won't stop running
Washes, rinses, won't shut down after cycle
1 Related Answer
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Aug 28, 2010
SOURCE: High limit light goes on
Well, while I must admit that "Percussive" maintenance, sometimes works, as you have discovered there is more to servicing than, just "Giving it a good whack" lol.
The problems with these units, is usually to do with the Thermostat, and/or the Main Controller Board, the MCB, is prone to "Spikes". "Surges", and mains borne problems.
The first thing to replace should be the Thermostat and or sensor thermistor. Usually we replace the Thermistor, or Temp Sensor, and, try that first, and if no go, then the Thermostat itself, and then if no go, the main Board. I provide you with a parts supplier below. Below that is the Jackson support website to assist you. Please contact them, and ask for a referral to an authorised repair center. Then ask the repair center for a "Quote" for the repair before allowing any work to commence. If you do not wish to DIY.
http://www.whaleyfoodservice.com/jacksonmachineparts.aspx
http://www.jacksonmsc.com/?xhtml=xhtml/jac/us/en/homepage/default.html&xsl=homepage.xsl
However it is my professional recommendation that you call a professional to attend to this matter.
Hi, my Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer, won't rinse and I have to manually turn dial to spin, any ideas please?
Beko washing machine, WMA 1512 W stops half way through wash cycle and leaves conditioner in drawer This video will show you how to keep your soap draw clear and how to service the parts
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Rinse and spin cycle keeps repeating at 11 minute time to 17 minute time and won't stop
Sounds like your washer does not empty enough water for the spinning to stop. Have you check that the filter(s) are not clogged?
My top dishwasher drawer won't finish through the cycle. It runs fine on rinse only but not any of the wash cycles. It stops mid cycles, beeps like it has been paused, then tries to start again
Try to feel the temperature of water inside the dishwasher. If it is normal room temperature for the hot wash cycles then it is likely the heater is faulty.
It is not easy to replace unless you have good experience with repairing dishwashers.
Hotpoint hswp1000m washer cycle fills with water for large capacity but when it goes to rinse it won't fill anymore than low capacity of water?
It can be due to a faulty water level sensor which evidently is a pressure switch. If the diaphragm is damaged it will require a larger water level to achieve the said pressure to shut the inlet valve in all the cycles.
Frigidaire FWT647GHSO when it gets to rinse first rinse cycle, it doesn't stop filling with water. It won't agitate or spin. It works well in the wash cycle, agitates and spins and advances
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
2answers
Top load maytag performa washer won`t stop flling both on wash and rinse cycles.
The switch the tube connects to shuts the water off. Will it cut off on high medium or low level. You can try blowing on the tube to see if it works. It should cut off when you blow.
I have a GE washer that during the spin cycle / rinse on my washer the water won't shut off and will run and run until I turn the water valve off. This occurs during spin cycle when it adds water but...
water valve or water presher switch my vote is water valve start washer when water is filling unplug from wall if water is still running it is the water valve if water stops it has to do with presser switch let me know what happens I will walk you threw how to repair thanks
Top Jackson Dishwashers Experts
ADMIN Andrew
ADMIN Andrew
Bonded Repair
Don A
Don A
Are you a Jackson Dishwasher Expert? Answer questions, earn points and help others
