20 Most Recent
Samsung WA5451ANW 4.7 cu. ft. Top-Load Washer Questions & Answers
I get an error code PE on Samsung washer WA5451washer
PE error code is a pressure sensor code, and more than likely the sensor will need to be replaced. Try unplugging the unit for about 5 minutes and see if it will clear it out. If not, will need to replace pressure switch and hose (switch looks like a little UFO under the console, pretty easy job.
10/9/2022 1:27:02 PM •
Samsung...
Answered
on Oct 09, 2022
Samsung WA5451ANW top will not open. Code
Have you tried to tilt the washer? When I tilted my washer 15 - 30 degrees and then I could open the lid. My problem was that I had a clogged filter I have not seen before.
8/30/2017 8:32:14 PM •
Samsung...
Answered
on Aug 30, 2017
My Samsung Model#WA5451ANW/XAA washer keeps repeating the rinse and spin cycle over and over and my clothes are still wet because spin cycle is not spinning clothes fast enough.
From the information you have supplied, I suspect that the machine is not draining the water away,
1] Check that the drain pump is working (it would be easier to hear it running, before the machine starts the spin cycle, or if your machine has a "drain down" feature)
2] If the pump is running, stop the machine and unplug it from the mains power. Remove the machine drain tube from the point where it is plumbed into the household waste pipe, and lay it down into a bucket, or large pan and allow the water to drain down [ you should expect to get up to 2 gallons (10 Litres) of water from the machine]
Allow the water to drain down completely by holding the drain hose as low as possible into the bucket.
3] once the water has drained completely, remove the drain hose from the pump and check that the drain hose is not blocked.
4] If the hose was clear, and the pump was running (in tests [1] & [2] ), it will be necessary to check that the drain pump, and the main hose from the tub to the pump are clear of obstructions.
Remove any foreign objects, and re-assemble the hoses to the pump to the machine, and the drain hose to the domestic plumbing.
Plug the machine into the mains power, and and set the machine to run on the "last rinse" and "spin" cycles and test to see if the problem has been rectified.
I hope this helps cure your problem.
10/14/2016 7:36:18 PM •
Samsung...
Answered
on Oct 14, 2016
