20 Most Recent GE WPGT9360EPL Top Load Washer Questions & Answers
I have a GE Harmony
when washers go into rinse cycle they use cold water so the clothes don't rinkle,i would say that you have a bad water valve located on the washer,you can try to run the wash at the beginning just with cold water,if the water comes in slow you have a bad valve,you can then run it on just hot water and see if there's a difference in how fast it fills.the strange thing is that it should pop up with an error code after 6 or 8 minutes because the washer is filling to slow,have you seen any codes come up?if it is the valve the part number is WH13X10017 and that valve is under the top console
11/11/2017 12:43:46 AM • GE WPGT9360EPL... • Answered on Nov 11, 2017
0answers
Problem has been detect with this unit
has an error code come up.
6/17/2017 8:19:53 AM • GE WPGT9360EPL... • Answered on Jun 17, 2017
0answers
Washer makes grinding noise when agitating and
termed as bad main bearing and seal costs about 150-180 for the parts and if you had a technician do the job they would charge you about 4-600. Big job takes experienced technician about 3 hours to most complete the job in 4-5. All this considering I would go with zert cheaper to find another unless you can perform the job yourself in which both the inner and outter tub have to be removed and seperated in the unit. If you have any further questions message me back. I await your reply Thanks Rick
1/31/2014 1:19:55 AM • GE WPGT9360EPL... • Answered on Jan 31, 2014
0answers
Touch screen not working
Do you have any display on the screen or is it completely dead?
10/20/2012 12:32:39 PM • GE WPGT9360EPL... • Answered on Oct 20, 2012
GE Profile Harmony Top Load Washer - Won't drain
After more thought, it dawned on me another possible reason. In my case, the washer is draining water, but it keeps cycling the pump on and off, thinking that the pump isn't working properly, and the washer doesn't go into its high-speed spin to eke the last bit of water out. It dawned on me that it could be that the pump is fine, but the sensor is lying, saying there is more water when there isn't.
I looked at the tube for the sensor, and noticed a small blockage of white soft stuff. I disconnected the sensor tube from the tub (in the back), managed to squeeze the blockage out, connected it back up, and now it all works fine (about 5 loads and I haven't seen the pump message)!
So if your pump is draining water successfully, but the washer keeps complaining and refuses to go into the high-speed spin, then perhaps this is your situation as well (or a bad sensor, etc.).
Note that I'm pretty sure the blockage is what ended up ruining my first pump. The blockage matches the color and consistency of the caulk/glue that was used to attach the sensor tube, so my suspicion is that too much was put on at the factory and ended up going into the tube, but not enough to cause problems initially. After several years of use and perhaps a bit of water mineral buildup, it finally became a full clog.
Finally, note that, as you may have guessed from the design of the machine, when you disconnect the hoses at the bottom, there's always a few cups or more of water in the two black hoses and the pump that it can't manage to push all the way to the drain.
8/23/2012 5:34:08 PM • GE WPGT9360EPL... • Answered on Aug 23, 2012
We have a GE Profile Harmony. After the washing cylce is over, water keeps leaking onto the clothes. Any ideas?
you have a bad water valve. you can replace the valve and it will be fine. I will warn you that working on your machine can be complicated. after you look closely at the how, you may decide that a pro is the best way to go. here is a link if you decide to tackle it yourself.http://www.partselect.com/ModelFrames.aspx?ModelID=467904&ModelNum=WPGT9360E0PL&mfgModelNum=&ManufactureID=2&Selected=00117836i01&Position=2&mfg=GE&Type=&Mark=2
5/13/2012 2:53:19 PM • GE WPGT9360EPL... • Answered on May 13, 2012
Stuck on "problem detected" screen
Press the Back Button and the Heart (My Cycles) buttons simultaneously for 3 seconds or more. This will reset the screeen. Diagnostics will then run. Let it run through the diagnostics on the screen and then the washer can be used.
3/21/2012 3:13:02 AM • GE WPGT9360EPL... • Answered on Mar 21, 2012
GE WPGT9360EPL Top Load Washer Logo
109 questions posted
Top GE Washing Machines Experts
Virgil Watts
Steve Sweetleaf
Steve Sweetleaf
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
View Most Popular
GE Washing Machines
  • GE Washing Machines
Most Popular Question
touch screen not working
  • Washing Machines
