I can't change aperture or shutter speed settings with the main dial in the non auto modes eg TV mode or P seting
Spillage or impact damage that breaks lands in the flexible top cover circuit can cause this problem, as can sand which wears away traces on the switch contacts on the circuit itself. Impact can also cause the flex from the top cover topull loose or twist sidewase in the flex connector on the main circuit. In most of the Canon Rebels the top covers are only available as complete assemblies.
SOURCE: Apperture and shutter speed settings
First select AV (Aperture Mode) to select the required aperture then switch to M (Manual Mode) and spin the wheel until you get the right speed.
Spurs34
SOURCE: I have a Canon EOS
I reset the software to Default setting and started again...that seems to have done the trick.
Thanks for your interest.
kp
SOURCE: Canon Rebel XT I can't change aperture or shutter speed in manual mode
You may try this. Reset all in the menu setup.
What you will be doing to to reset all the settings back to factory settings. Then you will want to go through the settings and reset them the way you prefer.
SOURCE: Rebel xt 350d slow shutter in action mode
need to be aware of lighting conditions as well. if the lighting conditions are low then the shutter will slow to compensate
SOURCE: Cannot adjust aperture or shutter speed in manual modes
Suggestion.... try to reset all settings to default. See what happens then.
The main dial which clicks ar it is rotated does not alter the shutter speed when it did before. So basically it has stopped working. I have reset everythig to default, but no difference. Could it have got worn down or is it possible that dust or whatever is trapped in side?I can still take photos in all the pre programmed settings but have no control of the ones you can alter
